Home > Puma (Tdci) > Bypass fuel filter? .. stuck on side of road |
bypass the filter temporarily to get it moving you cam but any crap in the fuel will end go to fuel pump and VCV
LR009837 fuel filter head part number |
21st Jul 2019 3:22pm |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 702 |
Been recovered now on the lorry of shame.
Click image to enlarge Ordered a new filter housing. How do these fuel lines come off? Press in the blue bit? 2008 Defender 110 XS SW - M57N2 / 6HP28X |
21st Jul 2019 4:01pm |
21st Jul 2019 4:08pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1635 |
these are really common to break on the TDci filter heads, i always blow them out with the air line, then straw on the silicone spray and give it a good blast in around the blue clip and the two "holes' on the bottom of the clip.
21st Jul 2019 11:56pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17489 |
Whoever decided to fit the TDCi filter head with plastic spigots really needs a good talking to, it was a really bad idea! As noted above, this is a very common problem.
22nd Jul 2019 7:10am |
Rkcorry Member Since: 23 Jan 2017 Location: Northern Ireland Posts: 226 |
I got a pair of these thinking i may never use them , though will say on these type of connectors they really are a god send.
They allow the pipe to be removed without stress of strain on the fitting, Click image to enlarge |
22nd Jul 2019 9:45am |
They’re for the “bmw” push style and very good I’ve knippex plug boot pliers I use for the same thing, there’s a “slide in” disconnect tool a bit like aircon disconnects for the “Ford” style larger connects
22nd Jul 2019 5:10pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 741 |
Are the pipes on the fuel filter housing plastic? I thought they were metal?
I actually replaced this hose to the fuel tank not too long ago as I kinda suspected that it was a potential air ingress source to my fuel system (it wasn't) and I was thinking of just getting rid of the push fitting then just clamping that sucker down with a traditional hose clamp line the good 'ol days. Will there be a potential issue is this were done? |
23rd Jul 2019 1:24am |
They’re plastic. I don’t see why you couldn’t go old school and use normal pipe and jubilee clips.
The pipes were difficult to get off as the clips on the main fuel feed pipes were full of dirt and wouldn’t release properly. Had to clean them out and help them off with a small screwdriver. Fitted the new filter housing and made a siphon pump (thanks to another thread on this forum and Amazon). I cut the ends off the old filter housing to make the right end for the suction pump to connect to the fuel line engine end and got all the air out. Had a pretty sleepless night on Sunday as she (the Landy) had to be recovered to the public carpark around the back of our house as we couldn’t get her back on our drive. It’s in a very quiet village, but you never know what those thieving will do. She’s back in the relative safety of our garden and under cover .. I slept better 2008 Defender 110 XS SW - M57N2 / 6HP28X |
23rd Jul 2019 6:28am |
Glad to know your Landy is safe and sound now.
So I guess I should get some hose clamps (jubilee clips) ready for any future, on demand "upgrades" to the connection. There should still be enough slack in the hoses to pull this off, correct? |
23rd Jul 2019 7:40am |
