![]() | Home > Technical > Part no. question... |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6657 ![]() ![]() ![]() |
LR027944 only appears in the Puma bit of the parts catalogue, so the BA is the 2011 time around
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17680 ![]() ![]() ![]() |
Thank you, obvious when you put it like that!
That would mean that I need the FTC5402 part, which is probably the Teflon-coated one that allows the diff cross-pin to fall out after a predetermined mileage! |
