Home > Puma (Tdci) > Clutch - manufacturers |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
what do you use ya truck for bw ? 2.4 90 XS
28th Jun 2011 4:22pm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
B+B will be fine ..... thats all we fit to Transits now, a few of which spend their life towing compressors and mini diggers.
Stopped fitting genuine [ford] units as B+B's were lasting longer Guns and Landrovers .... anything else is irrelevant. |
28th Jun 2011 6:44pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17573 |
Thanks. D-H, useful to know that.
Grockle - I use it for just about everything! At the moment I am doing about 750 miles per week (which means about £250 of fuel ) with nigh on a ton of tools in the back getting to and from a remote work site in Devon. Also sometimes tow anything up to 3.5 tons. When not doing that it is usually hauling steam loco or crane parts, or railway track tools and components. It had the first replacement clutch at first service (for first owner) due to death rattle, but the replacement then was the same inadequate design not the revised part, and the death rattle is now back. |
28th Jun 2011 10:32pm |
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 |
Be aware of some clutches offered on e-bay.
I have bought one as new design but it was old. Janusz www.yahodeville.com |
29th Jun 2011 6:19am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 |
Change the front prop to a double cardan one and the clutch/transmission issues disappear. Well it has on mine. 130's have feeling's as well you know
29th Jun 2011 6:29am |
Any idea why? On the face of it I don't see why this should make a difference to the clutch issue! If it does sort things out, it is an easy solution. I don't suppose a Disco2 front prop fits? |
29th Jun 2011 7:41am |
