Home > Maintenance & Modifications > Which make brake pads??
Matt
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Need to change the brake pads soon on my 2015 90, which aftermarket/perhaps genuine pads are people running and which ones do you recommend?
Thanks, 15 plate 2.2SW XS
Post #782273 20th Jul 2019 7:44pm
landy andy
Genuine. Yes they are made by someone else but who? All others appear to squeal on mine. Genuine don’t, and come with proper fitting kit.
Post #782275 20th Jul 2019 8:12pm
ibexman
Mintex
Post #782278 20th Jul 2019 8:37pm
zippo87
Scotland 1996 Defender 110 300 Tdi CSW Epsom Green
I’ve had good success from Pagid on the last 4 changes I’ve made - admittedly all different marques, BMW, Ford, Saab & Peugeot. But I’ll be using them again. Always good quality.
Post #782281 20th Jul 2019 9:13pm
I recently fitted a set of Borg and Beck pads to the rear axle of my 110 and they seem absolutely fine. Purchased from my local motor factors. Darren
Post #782283 20th Jul 2019 9:23pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
Mines the same as landy Andy, everything but genuine seems to squeal. Probably the more expensive option, but the squealing was driving me mad!
Post #782284 20th Jul 2019 9:36pm
Devon-Rover
Ferrodo with Ceramic brake grease (dunno if it helps just good practice) and I don't have brake squeal and it performs just as well as it did with genuine. Thumbs Up Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #782297 21st Jul 2019 3:45am
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
As above , just fitted ferrodo all round . Brakes very well and not a squeak . I actually didn’t copper slip the backs as I was told that the gel layer that the pads already have built in would suffice . So far so good https://www.instagram.com/hustynminepark/
Post #782309 21st Jul 2019 8:36am
roel
I buy the cheapest I can get. No squeel at all. Yes they don't last as long but also the genuine one will wear fast in wet sand. Half a block thickness in one day is common without abs and tc.
So I rather replace a little more often then spend loads of money. Mr. Green
I know most of you will disagree. Twisted Evil Roel
2003 90 Td5 (2009-now)
Post #782368 21st Jul 2019 2:29pm
Mo Murphy
Ferodo make the genuine pads.
I use mintex, for me they are the best combination of quality and value for money.
50 Shades of Pennine Grey
Post #782415 21st Jul 2019 5:39pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
I fitted some on my 2014 110 supplied by Euro Car Parts via eBay earlier this year for all four corners and they've been fine. I think they were Pagid (certainly not some unbranded ones) but they weren't very expensive. And no squeals.
Post #782442 21st Jul 2019 6:58pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I tend to use Delphi (AP Lockheed) as they come with anti rattle shins and have no problem with them.
I will not fit another set of Mintex pads again. They just squeal!
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #782449 21st Jul 2019 7:34pm
Martin
Site Admin
The factory fit ones in my 2.2 squeal a lot Rolling Eyes
Buy a quality branded pad, LR don't make pads.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #782517 22nd Jul 2019 10:27am
Matt
Thanks everyone, think I’ll try Ferodo pads this time and see how I get on with them, the genuine pads I’ve currently got have squealed from new anyway! 15 plate 2.2SW XS
Post #782911 24th Jul 2019 4:57pm
CharlieDonuts
France 2008 Defender 90 Puma 2.4 SW Galway Green
Just out of curiosity are the front and rear brake pads for a Defender 90 the same ?
Post #782962 24th Jul 2019 9:17pm
