Home > Td5 > Central locking and immobiliser - and dead battery ....
alexatnd
o.k. so my 2004 td5 with central locking and an immobiliser has a dead battery.
Assuming I can get back into it ( ignition key doesn't fit door locks) and apply power to battery via jump leads, that should get the doors open. However ...
Givent that you're supposed to use a specific key sequence in preparation for battery removal, if your battery dies and you replace it, will the engine start or is there some magic you have to do?
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost
Effie - 2004 110 TD5 County
Post #781683 16th Jul 2019 12:17pm
The specific key sequence for battery removal is to disarm the battery back-up sounder and nothing to do with the engine starting. Darren
Post #781686 16th Jul 2019 12:27pm
alexatnd
Cool!
So assiming i can get in .. she'll start . o.k. that just leaves why the battery was flat in the 1st place... Personally I think they all talk to each other... this dead battery on Effie has coincided with Gertie being put back together and back on the road. Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #781687 16th Jul 2019 12:45pm
NickMc
try a teaspoon in the door lock it'll probably work Rolling with laughter Rolling with laughter Rolling with laughter
Post #782491 21st Jul 2019 11:50pm
