Home > Technical > PEL500110, too cold?
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Hi all,
This weekend, I replaced the coolant in MY2009 Puma 2.4 (10 years, as per the schedule) and also changed the thermostat for a PEL500110 (as suggested many times on this forum). The new thermostat is a brand new, genuine LR part.
Previously, the coolant (as measured with the Scanguage) would sit around 93°C, sometimes reaching 100°C under load, whereas the CHT (Cylinder Head Temperature) would often go well above 100°C.
Now, with the PEL500110 fitted and the new coolant (Havoline XLC diluted at 50%), the collant temperature does not exceed 84°C and often go as low as 78°C, whereas the CHT does not exceed 88°C.
The car drives fine, the temperature needle is right in the middle, yet I fear that might be too low for the operating temperature... what do you reckon? Rolling Eyes “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #781550 15th Jul 2019 10:09am
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
As long as you bled the air out the system I wouldn’t worry.
Post #781558 15th Jul 2019 11:29am
o4dn
Oh sure, we followed the WSM procedure to the letter and it worked well, so I reckon it's bled correctly.
It's more the temperature that worries me... I mean, for sure, I knew installing the PEL500110 which opens at 82°C instead of 88°C previously would result in a lower running temperature, that was the goal, but that's a lot colder than I was expecting... “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #781563 15th Jul 2019 12:18pm
dorsetsmith
PEL500110
82°C, soft spring rate.
This is the PRT usually suggested for retro conversions on MGFs and pre-2003 MG TFs.
Specifications and additional product information Discovery 2 - All 2.5L TD5 diesel engine models from (VIN) 5A476243 on - Quantity Required - 1
Freelander 1 - All 1.8L petrol engine models from (VIN) 1A000001 on - Quantity Required - 1
PEM100990 is a PRT (pressure release thermostat) for a MGTF LE500.
87°C, medium spring rate.
Defender 2007 on Thermostats- All 2.5L TD5 diesel engine models defender
Post #781567 15th Jul 2019 12:31pm
o4dn
@dorsetsmith, I'm not sure I'm following, you mean PEM100990 would be for the Puma and PEL500110 for a Discovery TD5? “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #781572 15th Jul 2019 1:11pm
dorsetsmith
yes
PEM100990
Puma 07 to 2016 and defender TD5 1998 to 2006
PEL500110
Post #781587 15th Jul 2019 3:49pm
o4dn
Right, that's the point, several people on here have changed the original PEM100990 for a PEL500110 to get lower temperature, but I am surprised that it gets that much lower Smile “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #781595 15th Jul 2019 4:55pm
Balvaig
I am not sure you have the science correct. A thermostat merely operates at a fixed temperature. It cannot lower the temperature in a system. The opening temperature determines the speed of raising the temperature to a fixed point after which the mechanical heat will determine the final temperature. As long as the mechanical heat exceeds the opening temperature of the thermostat then it is this final heat which you will measure.
So as your final temperature exceeds the thermostat opening temperature the measured heat is determined by the cooling capacity of the system (i.e the radiator etc)
I would suggest that the fact you have changed fluids is the reason there is a difference in temperature, not the thermostat.
By using a lower opening temperature thermostat you will delay the warming up period of the engine as coolant will reach the radiator sooner ( especially in winter). However the final temperature will not change due to the thermostat as your engine temperature exceeds the opening temp of the thermostat.
Probably opened a can of worms here. Whistle
Post #781598 15th Jul 2019 5:27pm
o4dn
Oh sure, the maximum cooling capacity of the entire system does not depend on the thermostat, however the thermostat regulates the running temperature under normal circumstances.
Anyway, I found out the old thread, it was https://www.defender2.net/forum/topic32086.html
Looks like my observation are in line with others, so I guess this is expected Smile “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #781606 15th Jul 2019 5:53pm
Balvaig
The other scenario is that the old thermostat was sticking partially closed, which would result in the temperature being higher due to lack of cooling by the radiator.
Post #781607 15th Jul 2019 5:56pm
BrickBox
Evening bump on this thread. When you have swapped to the cooler running thermostat, which one did you buy? Genuine one only, or are other brands sufficient? 2008 2.4 110 Utility Station Wagon XS.
Post #1005660 28th Aug 2023 5:34pm
TexasRover
Personally I would go genuine on this and the right part number for the application.
Perfectly affordable and just as stated in this thread the actual temperature rating is important and colder is NOT better even in warmer climate, so best to go with what Landrover considered to be the correct temperature.
If a system overheats there is not enough capacity to cool. Unless of course the thermostat is broken fitting a cooler thermostat is not going to make any difference.
Engines that run too cool don't have optimal lubrication and or combustion.
Capital punishment should be reserved for those mechanics that remove thermostats (not possible in most LR applications).
Post #1005666 28th Aug 2023 7:14pm
BrickBox
Brilliant- thank you.
It’s just a bit of evening reading and learning. I’m not looking to purchase a thermostat right now. 2008 2.4 110 Utility Station Wagon XS.
Post #1005668 28th Aug 2023 7:23pm
Dinnu
And old thread, but worth mentioning
Not familiar with the Freelander, but on the Rovers with the K series engines, the thermostat was on the radiator outlet / engine inlet, so might also be one of the reasons why the opening temperature of the thermostat had to be lower. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1005669 28th Aug 2023 7:23pm
