ABS light problem sorted .. sort of
I’ve had an intermittent issue with the ABS light coming on. Decided to check all abs sensors and found the problem to be a bit bigger that I was expecting. .. broken coil that had rubbed through the abs wire!
.. new springs ordered and will change discs and rebuild calipers while I’m here as they don’t look the best .. slightly bigger job than anticipated!
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
