Home > Maintenance & Modifications > Defender 2007 indicator problem
boardstein
Hi I have just joined this forum and would really appreciate some help, I have a defender 90 2007 with the puma engine. My indicators on one side flash quickly on the dashboard and the rear left indicator ight is not working, I therefore changed the bulb, still no luck, i then changed the relay, but no luck again, I changed the connector to the bulb, no luck still not working, could anyone help please.
Post #781364 13th Jul 2019 6:58pm
mick
Probably a bad earth
Post #781365 13th Jul 2019 7:29pm
boardstein
Thank you Mick, how can i check this?
Post #781366 13th Jul 2019 7:31pm
Likely an earth as mentioned. I would check the earths on the transfer box. Remove, clean, replace, protect.
Before you do that though if you have one or access to use a multimeter to check continuity on the earth side and for voltage on the live side.
Was this LED or Standard (Incandescent light bulbs.) WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #781386 13th Jul 2019 9:40pm
grafty99
I would say corrosion in the bulb holder. 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #781390 13th Jul 2019 9:50pm
boardstein
Steve and Grafty thank you, they are std bulbs, so it sounds like the earth - thank you for your help
Post #781433 14th Jul 2019 10:56am
