![]() | Home > Maintenance & Modifications > Wiring Up Daytime Running Lights to my Defender 90 |
Nadine90 Member Since: 07 Jan 2018 Location: CAERPHILLY Posts: 49 ![]() ![]() ![]() |
what lights are they ? are they Ring ones ?
boardstein Member Since: 13 Jul 2019 Location: leicestershire Posts: 10 ![]() ![]() |
No, They dont have a brand name on them
i know the ring ones wire up to the battery and the ground and to side lights so when you put on the side lights the drls will dim.
Thank you Nadine, Ive tried that, but then the lights are on, even when the ignition is switched off
may need to wire up to ignition live feel then ground and side lights then.
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2320 ![]() ![]() ![]() |
1. Take an ignition switched supply
2. Put it through a normally closed relay to the DRLs 3. Tap into the side light supply and take the wire to the relay to open it when side lights are turned on. Hey presto, dimming DRLs HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Mo and Nadine, thank you, that makes a lot of sense, last question how do i find and tap into the ignition live feed? many thanks
boardstein
the one I have used in the past is the white/orange wire to the back of the radio in the dashboard this thread will help https://www.defender2.net/forum/topic5492....=checktemp Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6658 ![]() ![]() ![]() |
That's not a true ignition feed, it cuts out when the starter is turned and then comes back on.
White/green is ignition. Found on most of the dash switches. ![]() ![]() |
Martin and Martink, thanks guys will go through this tomorrow
Hi guys
Do DRL have to dim when the side lights are on, as I did not bother with the side lighter connection and then come on when the ignition is turned on and stay on when side lights are on, but no dimming? |
Yes they do.
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2536 ![]() ![]() ![]() |
They should either dim as Mo says or they should extinguish when side lights are switched on. Defender 90XS SW
Thank you, this is very helpful
