![]() | Home > Maintenance & Modifications > Safety Devices Cage Accessory |
Not_Given Member Since: 25 Dec 2017 Location: UK Posts: 94 ![]() ![]() ![]() |
I’m about to have an SD external cage fitted to my 110 and was perusing the SD website when I stumbled upon these:
https://shop.safetydevices.com/collections...pgrade-kit Anybody have experience with whether they’re worth having? Seems a lot of money for some rubber gaskets, especially as the cages aren’t cheap in the first place! Seems the stock gaskets are ‘foam’. However, I will stump up the extra £50 if the consensus is positive. I would appreciate any feedback from those with knowledge/experience of these. NG |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
I’d fit them. Land Rover fitted them to my Black and I think it would look a bit unfinished without them, although yes, it does seem rather expensive for a few bits of rubber. 2002 110 td5
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2193 ![]() ![]() |
My cage came with them from standard. Instagram @defender_ventures Empire Tuning - Agent |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 ![]() ![]() |
ignore
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 685 ![]() ![]() |
They come with the cage, when I checked with SD when they fitted mine they said they were only on the website as replacements for existing... I had the same concern.
By all means check with them when your cage is ordered but should be ok. They're part of the cage to body sealing mechanism. You could do them with sealer but using these and a small amount of sealer is better. |
Thanks for the advice, everyone. I’ll double check with the fitter..
NG |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2285 ![]() ![]() ![]() |
They came with mine too originally.
Thread update for those who care:
Cage supplied and fitted with a full set of grommets! Clearly, replacements are available if/when the rubber gives up. NG |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2656 ![]() ![]() ![]() |
![]() Click image to enlarge When I fitted my SD cage the front legs had the rubber seal but the four for the tub were a neoprene foam. As the fit was so tight the neoprene seals want to fold under the cage feet and were a real Pita. Go with the rubber ones if SD still don't supply them as standard. |
