Home > Technical > Puma clock
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
Puma clock
The clock is working but the time is incorrect but for some reason the buttons don't work to adjust the hands. Any ideas please?
Post #781307 13th Jul 2019 7:34am
Roy5695
Take centre fascia off, remove the clock from the fascia and reseat/inspect where the buttons go for problems.
If you can be bothered to do that. Pull the clock fuse and then re insert when the time is right 😂 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #781309 13th Jul 2019 7:42am
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Thumbs Up 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #781311 13th Jul 2019 8:43am
ginjez
Great idea. Thank you Thumbs Up
Post #781377 13th Jul 2019 8:01pm
Sulisuli
Priceless Roy Rolling with laughter 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #781382 13th Jul 2019 9:03pm
muddypaws
England 2009 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Try squirting some switch cleaner around the buttons - my radio used to mysteriously turn itself on often in the night when the vehicle was locked. Judicious used of contact cleaner solved the problem.
Alternatively, the previous suggestion sounds perfect!! Richard
Defender 90 SVX
Post #781389 13th Jul 2019 9:49pm
