![]() | Home > Puma (Tdci) > Oil cooler keep failing |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2448 ![]() ![]() ![]() |
No one
![]() ............................................................. Earth first. Other planets later |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
I’ve just replaced the thermostat in my oil cooler as it was leaking coolant and it didn’t have the thermostat in from new,so maybe leave the thermostat out.
I was not aware there was a thermostat in there! Puma 110" SW
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 ![]() ![]() ![]() |
Hi,
Sorry, I can not help you. 175.000km, I do not even know where it is. I hope you find the reason Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1330 ![]() ![]() ![]() |
Found this on a Ford Transit forum regarding the 2.4 Puma :
My oil pressure @ idle is ~30-35psi when cold....TBH...it doesn't change much even when warm, maybe 2-3psi or so. Ford's spec for min oil pressure @ idle is a tad over 18psi, and 29.4psi @ 2000rpm. I have no idea if the details are correct. Not sure if engine oil pressure is reported through the OBD diagnostics or not, but if so, you could check the pressure and compare to the numbers above. Or if not, temporarily fit a pressure gauge with a tee piece into the oil pressure warning switch location. |
Big Harold Member Since: 09 Jul 2018 Location: nsw Posts: 71 ![]() ![]() ![]() |
My 2.2 oil pressure is;
Idle cold 48 psi Idle hot 24 psi 2400 rpm hot 54 psi ECU will not read oil pressure. I have fitted an oil filter adapter which has pressure and temp. Mark |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2660 ![]() ![]() ![]() |
Wow, that is a lot of oil cooler failures for that vehicle. I've never heard of failures on that component before, so there must be something strange going on.
FYI, on my 2010 2.4, the oil pressures are: cold idle: 5.4 (winter) - 5 (summer) bar hot idle: 1.6 bar hot under load (120kmh/2500rpm): 4.5-5 bar -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
That is good data
Fernando Member Since: 25 Oct 2017 Location: CABA Posts: 92 ![]() ![]() ![]() |
What is the symptom, throw the oil?
Exactamente Puma 110" SW
Ontdekker Member Since: 25 Nov 2009 Location: Centurion Posts: 11 ![]() ![]() ![]() |
That corresponds to my readings of my 2.4 as well with the Madman system |
