Home > In Car Electronics > Front Fog/Spotlight Switch Issue |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 902 |
Update: the switch is not faulty. Is it the relay then? Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
9th Jul 2019 5:05pm |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
The back lighting should have its own feed from an orange cable, I used a tap off from one of the original switches on the dash.
This orange cable should be connected to pin 2 Pin 3 or 4 should be connected to earth. Pin 5 connected to the blue with white trace cable which is the full beam power wire. And pin 1 should be connected to terminal 85 on your relay. The switch is an earth switching switch rather than a power one... 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
23rd Jul 2019 5:12pm |
MYSTERY Member Since: 14 Jun 2019 Location: Torquay Posts: 10 |
switch connection
27th Jul 2019 11:37am |
Tribord Member Since: 20 Apr 2013 Location: France Posts: 220 |
Just checking - is this last wiring diagram the best way to wire in spots (with direct connection between 30 and 86) when wiring spots without high beam trigger (just on-off switch)?
5th Feb 2020 6:28pm |
Without a switch, pin 85 on the relay would need to be connected directly to earth for it to work. Darren
5th Feb 2020 7:44pm |
LRAnorak - sorry I didn't quite understand. I am using the switch, but not a high beam trigger.
I have it wired as per above diagram, and it works. Just wondering if the relay link is the best way of doing it. |
5th Feb 2020 8:22pm |
Ah, sorry - my mistake. I can see where you've altered the original diagram now.
Yes, that would work fine. The switch is used to earth the relay coil, which has a permanent live supply. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
5th Feb 2020 8:36pm |
Horneteer Member Since: 10 Feb 2015 Location: Cornwall Posts: 60 |
If you wanted the bar to work only with head lights, then do away with the red link between pins 30 and 86 and connect a head light feed on to relay pin 86. |
20th Feb 2020 9:46pm |
I wanted to keep the spots separate from headlights, so used as per diagram above. Working well through the bearmach switches for spots and rear work light.
Click image to enlarge |
21st Feb 2020 6:53am |
WITH HEAD LIGHTS
21st Feb 2020 8:35am |
ForeignCartographer Member Since: 15 Jul 2021 Location: Scotland Posts: 13 |
Hi,
Don't laugh at me for this question but, how do I connect the ground/earth from the switch? Can I splice into a ground wire from another switch? Cheers Ben |
15th Jul 2021 1:49pm |
Yes you can although any convenient earth point will do. Darren
15th Jul 2021 2:12pm |
Thanks Darren
15th Jul 2021 2:42pm |
Hi again!
I was wondering: does the switch have to be grounded in order to complete the circuit and work, or is that only for the lights on the switch? Cheers Ben |
17th Jul 2021 11:34am |
