Home > Camping, Caravanning and Holidays > Roof tent mold
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
Roof tent mold
Hello,
I have made mistake leaving my roof tent installed during wintertime. Now I have mold problem.
Is there any safe way of cleaning it which will not compromise water resistance of the canvas?
The tent is ARB Simpson II.
Cheers!
Janusz Janusz
www.yahodeville.com
Post #780759 9th Jul 2019 7:14am
Zed
Post #780764 9th Jul 2019 7:28am
yaho
Thanks, I will try Nikwax and post results. Janusz
www.yahodeville.com
Post #781568 15th Jul 2019 1:32pm
gilarion
Nixwax is a great product however I would first soak the area with a mould remover as you will need to completely get rid of the 'mould spores' before using it as often washing alone will not do this and if not removed the mould will just come back. Not even boiling water will remove them. Soak the area in mould remover let dry brush off then treat with either Nixwax or Grangers.
The good thing about mould remover is that it will also remove a lot of the staining caused by the spores. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #781575 15th Jul 2019 2:30pm
yaho
Tried Nikwax, it has not removed the stains, not even made it less visible. The effect AFTER is exactly the same as BEFORE. I have also tried much stronger chlorine based mold remover - it works pretty good. As I am not sure how it affects rain resistance on the canvas I have tested it on small patch and will see how it behaves. Janusz
www.yahodeville.com
Post #783735 29th Jul 2019 9:21am
jst
does chlorine not eat clothing and hence the roof fabric? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #783777 29th Jul 2019 12:56pm
Eduardo
After doing that, probably the rain resistance is affected. So now you can apply Nixwax to avoid problems (I use to do that with several raincoats and working well).
Cheers! Eduardo
Post #783789 29th Jul 2019 2:19pm
geobloke
I would fall back on the age old vinegar and bicarbonate of soda method.
Saturate the affected area in white vinegar (not malt)
Mix a paste of Bicarb and vinegar and rub in to the affected area.
Rinse off
You could use a detergent at this point or not.
Rinse off
Re-apply water proofing of choice.
If you are unsure try this in a discrete area first then where you need it. Tent fabric is usually very hard wearing so I would think it could easily cope with this treatment.
Post #783790 29th Jul 2019 2:22pm
