![]() | Home > Puma (Tdci) > Maf sensor problem |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 305 ![]() ![]() ![]() |
Maybe give the MAF sensor a good clean.
Clear the fault code then they again. |
sjc501 Member Since: 05 Feb 2018 Location: Glasgow Posts: 148 ![]() ![]() |
Thanks for reply . I tried that cleaned sensor reset code and it came back on as soon as I drove about 500 yards. I then got a new one fitted today and the same happened. Defender has had a remap from JE Engineering with intercooler etc . Not sure if thats relevant .
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Did you check the wiring and connectors? Eduardo
MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 ![]() ![]() ![]() |
Hi,
If it is a td4, could be a leak in airtubing from turbo to engine, I did have it already 2 times. I did change the maf sensor first time before understand that the error was not the sensor but the airflow not right . Not easy to find where and depends where, not easy to change Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20718 ![]() ![]() |
Check the hose nearest the steering column that it hasn't rubbed and punctured.
That is a known failiure point. Just a possibity WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Bogblaster Member Since: 04 Jun 2007 Location: Glawstershire Posts: 119 ![]() ![]() ![]() |
Most likely a split intercooler, JE did my tune in 2017, had one changed after 12 months so about 11 months ago and yesterday with no trailer on I got the dreaded loss of power and a sort of bang, reset DTC seems to be OK but I fear the worst. I have already put on silicone hoses. 2019 MY Disco 5 HSE Lux
Audi A4 Avant 3.0L TDI Quattro - WOW 2016 90 Adventure |
