- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Graham048
P1336 Crankshaft Position sensor | |
Hi we have installed a new 2.2 puma engine into our 110 landrover when it is started we get a crank shaft position sensor warning.
with Fault code – P1336, Crankshaft/Camshaft sensor range/performance. Mechanical Failure wrong mounting Position.
Have tried replacing sensor with new one , re positioning it, removed engine to find the TDC on the flywheel and set distance as per the manual all to no avail
Any Ideas.
Many Thanks Graham Hill
2nd Jul 2019 9:15am |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
