![]() | Home > Technical > Working little light |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 ![]() ![]() ![]() |
So after many searches, I Found the correct wire, but it turned out that on that end I had no power either. At the end it turned out to be the fuse which Is had to research to as the information on the fuse lid dit not give me clear information.
In other wordt: solved. |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2320 ![]() ![]() ![]() |
Happy days! What a nuisance but glad you got it sorted > 110 XS Double Cab
Just for future reference: it is the middle red wire, not the one on the side.
The fuses concerning the little side lamps are second row on the bottom. https://www.lrworkshop.com/electrics/defen...nd-headers https://www.lrworkshop.com/connectors/defender-2007/C1267 |
