Home > In Car Electronics > CB gurus, I need your guidance |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1599 |
not many cb places left that can offer real advice
cb shack at lymn truck stop or one at Wakefield jct 41 truck stop Jim at communication eleven or cb11 is a good bloke been using him for 20+yrs |
28th Jun 2019 7:47pm |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1841 |
I've had a CB in the car for ages, but not a 'big user' - mainly for personal/occasional convoy stuff.
Just bought a new one though, and I found www.cbradio.co.uk to be very good. Think I might have bought the last one from them too. I've used a PSM aerial mount before - on the rear of the roof on the nearside for me; and a stainless gutter mount above the driver's side B pillar. At the moment the PSM mount is in use, but I've now got a roof tent which will foul that, so I was digging out the gutter mount to see if I still have all the bits. Another handy thing in a LR, given the amount of ambient noise, is an external speaker which you can just mount to the roof lining above the driver's right ear. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
28th Jun 2019 8:00pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5699 |
You need to decide if you want it permanently or temporary.
Temp I would fit bracket to roof rack. That way easily removed and reapplied when required. Permanent, I would go rear panel by rear door (where you often fit work light) or front wing, so it matches fm aerial. You can get quick release mounts, so you don’t need a big whippy thing all the time. There is a good range of aerials on Thunderpoles website, and plenty of info. I think the do a CB aerial tha5 is short stubby black item, like the flexible FM aerials. The shorter the cable the better to a point, but you want at least a meter of cable to it. A gutter mount, for me, is a no no. They mark the paint, and often don’t stay on or snap, then causing other damage. |
28th Jun 2019 10:14pm |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 937 |
I’ve also bought from thunderpole and can recommend. However an alternative source of equipment and advice is:-
http://4x4cb.com/ |
29th Jun 2019 6:18am |
^^^That's Communication Eleven. Jim who runs it is a top man. Darren
29th Jun 2019 7:11pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1916 |
Thanks for the info
Will give the mentioned suppliers a ring on Monday I purchased the CB for an upcoming expedition and will probably only us it one such events so a removable type would be ideal. Thanks chaps 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
29th Jun 2019 9:21pm |
