Home > V8 > erratic slow speed running
oneten110
engine on carbs, SU.
Starts up and runs fine on choke.
Back the choke off and it starts to run rough, like it is only running on 4 cylinders, with an occasional pop from the exhaust to suggest that at least the other 4 cylinders are trying to run. Increase the choke and it runs better.
On trying to set off it definitely feels as though it is running on 4, until it gets to about 2000 rev/min then the other 4 join in.
Been through the carb set up from scratch, as per the LR factory manual and no improvement.
Any thoughts chaps? It is not a Defender, it is a One_Ten
Post #778625 23rd Jun 2019 2:30pm
oneten110
Found the problem, fixed it. It is not a Defender, it is a One_Ten
Post #778837 24th Jun 2019 8:30pm
Iggle piggle
United Kingdom 1989 Defender 90 V8 Petrol ST Alpine White
Rocker cover breather popped out??
Post #778842 24th Jun 2019 8:44pm
oneten110
No It is not a Defender, it is a One_Ten
Post #778849 24th Jun 2019 8:57pm
dorsetsmith
need to no only then Whistle pray tell
Post #778906 25th Jun 2019 8:16am
oneten110
component failure deep within the bowels of the carburetter It is not a Defender, it is a One_Ten
Post #778975 25th Jun 2019 5:42pm
oneten110
correction, not so much component failure as assembly technique failure It is not a Defender, it is a One_Ten
Post #779162 26th Jun 2019 8:36pm
