![]() | Home > Technical > Exmoor trim seat wiring |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5871 ![]() ![]() |
dioliahary Member Since: 18 Jan 2015 Location: Manchester Posts: 668 ![]() ![]() |
That’s spot on, I did search but failed to find the right info.
Question, I have two setting switches ( high and low) but only one positive feed to the seat. So if you require the high and low setting do you have to fit an in line resistor to the lower setting wiring. This question is for curiosity only as I will just use one setting, thanks again. 1990 200tdi conversion 90 |
There are two elements in each part of the seat. One element will be low heat, and one element high heat.
So you put live into the switch, which to use the full ability of the elements will be a three way switch (two on’s and one off) then as you operate the switch it will be low heat - off - high heat. |
