Home > In Car Electronics > Wiring a 5 pin rocker switch
itolond
Singapore 1997 Defender 110 300 Tdi SW Alpine White
Hi Forum,
looking to wire a 5 pin rocker switch and need some guides.
accessory operation is ok, my question is around illumination - in the case of a 2LED DPST rocker switch I understand the following
1 LED is for the dash light illumination
1 LED is for the 'on' position.
I want to set up a situation where the 'on' LED will flash with the hazard indicators. Given my mods have 12VDC to an electronic flasher I cannot run with a flasher input as usual. So the only method I see is o hook up the LED + to one of the indicators leads and the negative would then be completed via switching on the rocker switch - providing 12+ the hazard circuit and the LED flashing in time with the indicators.
an alternative would be the have the dash illumination LED flash when on?
any pointers here as it would seem I may need an on/off rocker with separate illumination circuit?
Post #778697 24th Jun 2019 4:17am
If you've only got a 12v output of some description from your hazard circuit or indicators, then you could use that to switch a relay which, in turn, switches the rocker switch LED ground on and off. It's not the most elegant solution but would be relatively easy to set up, particularly if you could use a solid state relay rather than a regular automotive one. Darren
Post #778725 24th Jun 2019 8:55am
Actually, thinking about it, you'd have to use a hazard circuit output, otherwise it'd light up every time you turn left (or right). Darren
Post #778726 24th Jun 2019 8:56am
Martin
Site Admin
How do you have it wired at the moment?
Let's assume it is:
2: Permanent Feed
3: Hazards 12V Feed to Flasher Relay - how have you wired this, is this isolated from ignition 12V?
6: Dash Illumination
7: Ground
8: nothing but want this to ground with the hazard flash only
With the switch 'off' does grounding pin 8 illuminate the LED or only when it is in the 'on' position - have you tested this?
I would expect it only to illuminate the LED when it is on, as normally you would connect pin 8 to ground.
So, you want to create a pulsed ground from a pulsed 12V (either indicator circuit) - this can be done with a transistor circuit or a relay (only a tiny relay needed not a 30/40A cube).
However depending on how you have wired it, your pin 3 may also be at 12V when the ignition is on, so this would give you a flashing hazard switch when the indicator you have picked to create the pulsed ground is on.
Need to know more about your wiring to fully advise.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #778741 24th Jun 2019 10:16am
itolond
The following is true:
2: Permanent Feed YES
3: Hazards 12V Feed to Flasher Relay - how have you wired this, is this isolated from ignition 12V?: No relay, just electronic controller which gets its power from constant, hazard simply provides 12VDC + as a signal for the electronic controller to use both signals (which are independent circuits) hazard are contstant 12VDC+ as well
6: Dash Illumination - from light switch
7: Ground - yes
Post #778742 24th Jun 2019 10:30am
Martin
Site Admin
OK how are the indicators supply (normally ignition 12V) wired to your electronic controller?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #778746 24th Jun 2019 10:49am
itolond
Correct, the onboard controller decides how to distribute power based upon inputs ( RH/LH or hazard)
Post #778749 24th Jun 2019 11:34am
Martin
Site Admin
OK so your indicators work all the time, ignition on or off?
Anyway, if the wire from switch pin 3 is at 12V ONLY when the hazards are on (test with multimeter, switch OFF, indicators ON), then you can do what I said above. Use a feed from one indicator side to create a pulsed ground for pin 8.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #778750 24th Jun 2019 11:37am
