Home > Maintenance & Modifications > HELP! Indicator Stalk
Stiff1
So after lengthy trouble shooting I have decided I need to replace my indicator/ horn/ lights stalk.
Am going to get this item:
https://www.ebay.co.uk/itm/LAND-ROVER-DEFE...0887386457
Looking at the pictures, does the steering wheel need to come off to fit this over the splined column?
Thanks in advance.
Post #778688 23rd Jun 2019 10:51pm
grafty99
It does yes Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #778689 23rd Jun 2019 11:03pm
8619simon
Wales 1995 Defender 110 300 Tdi CSW Epsom Green
Yes, steering wheel off and remove the shroud around the steering column and it just slips over the end of the column. There is a screw on the top you use to tighten it on the column, you'll see it when you take the old one off, don't over tighten this as it's easy to snap the plastic Rolling Eyes
The indicator stalk is often prone to failure so it might be worth considering an OEM one from Lucas, yes it will cost about twice as much but is likely to last a lot longer.
Post #778691 23rd Jun 2019 11:07pm
Stiff1
Thanks for that, tried to remove it a few weeks ago to check no. of splines but would not budge, may need to find a local garage with a puller.
Post #778692 23rd Jun 2019 11:23pm
I have fitted a replacement switch before now without removing the wheel, by taking the switches off their respective metal plates and just swapping the switches. It is possible.
However if you are tempted be careful since there are little springs and internal component which can fall out (the springs will depart at high speed) if you're not very careful, then you have to figure out how to put it back together again.
It is perhaps telling that the second time I changed the stalk switch I took the steering wheel off, and also rewired the headlamps to use a proper relayed circuit to stop the switch failing every six months.
Post #778712 24th Jun 2019 8:18am
hank
Post #778717 24th Jun 2019 8:38am
I need to replace mine too, my only concern is getting the wheel off and it not budging.
Would a soft mallet help break the tightness used carefully?
I know the nut should stay partially on whilst trying to remove the wheel.
If a puller was needed. (Hopefully not.) what type would be needed for a steering wheel like in the above video?
Pullers can be a godsend if you have something really tight, much akin to like the wiper spindles. WeWillWin🇬🇧🇺🇸
Post #778756 24th Jun 2019 12:48pm
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Give the splines a good soak in WD40 or releasing fluid for a few days/week. A quick squirt once a day.
Post #778757 24th Jun 2019 12:55pm
williamthedog
Stick your knees under the steering wheel whilst hitting the top with your hands. Always works for me Thumbs Up
Post #778758 24th Jun 2019 12:59pm
hank
You can make a puller out of a small offcut of steel with two appropriately drilled holes and two m6 bolts > 110 XS Double Cab
Post #778774 24th Jun 2019 2:03pm
Thank you all. Thumbs Up
Mine is working, but the clip around the column is broken so the assembly is a bit loose.
It's a job I need to get done at some point shortly.
I was going to go for the Lucas type as mentioned here. WeWillWin🇬🇧🇺🇸
Post #778836 24th Jun 2019 9:29pm
Stiff1
So... got the wheel off, rubber mallet required.
New stalk arrived but in testing by hand left turn goes fine, indicate, turn blue collar to simulate turning wheel, feel click, rotate back to centre and indicator self cancels. Do the same to the right and the indicator cancels as you make the initial turn...
Post #779304 27th Jun 2019 11:47pm
Martin
Site Admin
Pattern or Lucas switch? Either way it's faulty (lots of them do it).
It can be sorted but means disassembling the switch which has little springs and pins everywhere, and you shouldn't be doing it with a brand new item.
I would be seeking a replacement.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #779329 28th Jun 2019 8:39am
Yes, if a brand new item I would be asking for a replacement as it's not fit for purpose if it doesn't operate correctly. WeWillWin🇬🇧🇺🇸
Post #779363 28th Jun 2019 12:20pm
Stiff1
Agreed, will report back on progress.
It's a real pain when you are geared up to do what should be a simple job and have to put it on hold and reassemble everything.
Post #779371 28th Jun 2019 1:16pm
