![]() | Home > Puma (Tdci) > Live feed in engine bay for running lights |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 546 ![]() ![]() |
Are you wanting live all the time or live through the ignition
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 748 ![]() ![]() ![]() |
Live all the time.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20749 ![]() ![]() |
Alternator output, fused as close as possible in-line.
The stud has a plastic cover and a specific Torque. ![]() ⛽️🛢️⚙️🧰💪 |
Having taken a look this evening getting access to the alternator output on the TDCI is a sod so need a new plan.
The bumper lights are fused with a 3 amp fuse (2 lamps that have 5 x 1.5w LEDs so not pulling a lot of current). Any other ideas? |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1242 ![]() ![]() |
Hi
I also gave up on the alternator and decided to go back to the battery, fitted a voltage sensitive switch and this has been working just fine. Its a fairly easy route back to the seat box area and everything is contained there for future access. 1984 One-Ten CSW 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17718 ![]() ![]() ![]() |
The main power connection from the alternator to the battery on the TDCi runs in the harness that passes over the top front of the engine, so it would be extremely accessible to tap into this cable.
Thanks Blackwolf. Can you be any more specific on its location? Sorry electronics are not my strong point!
