Home > General & Technical (L663) > expedition in the New Defender |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17466 |
I wonder if the screen will have messages like "Warning: Multiple oil leaks".
21st Jun 2019 11:02am |
The joys of AdBlue on Martin’s D5 forum. Just one of the topic threads on the matter.
Eric https://disco5.co.uk/forum/thread1842.html You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
21st Jun 2019 11:50am |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1319 |
Talking of low range, do we know if the new Defender will be blessed with a dual range transfer box? |
21st Jun 2019 2:50pm |
That will be very interesting to see. Personally I suspect that its 4WD system will be based on a Haldex unit not a centre diff, but I would have thought that the range change was a feature that had to persist. We shall see.
21st Jun 2019 3:43pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2645 |
most likely, they will want it for its off-road cred -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
22nd Jun 2019 6:34am |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
My wife drives a Mercedes GL320 Bluetec. Love the vehicle, the biggest issue is AdBlue. The AdBlue tank has already been replaced under warranty ($1200 part) 2 NOx sensors and DEF injector needed to be replaced also... by far the most expensive portion of repairs over the 9 years we have had the vehicle.
Now other components of the system are failing again, and with the dealership being the only one that can clear the "remaining starts" code it's close to a $10,000 bill for them to replace items that are going to fail again. Biggest issue is if you drive a DEF equipped vehicle short distances it will clog the system with unburnt AdBlue. Solution, rip it all out, re-program the ECU and carry on. Let's hope Land Rover's AdBlue system is better than Mercedes! it's a Landrover thing... my renovation thread: http://www.defender2.net/forum/topic40792.html |
22nd Jun 2019 3:27pm |
