Home > Wheels & Tyres > Terrafirma Dakar tyre options |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 |
This is what they look like with no spacers and 265/75 x 16 AT tyres: -
Click image to enlarge Not sure how they would look with 235s however, but i'd be tempted to try them anyway. Mine drives much more nicely with narrow tyres so have reverted to 7.50s on wolf rims. I would advise with those wheels that you make sure your drive flange bolts do not have the sharp edges of the hex heads proud of the hub centre because when you slide the wheels on it takes a neat line of paint off the rims, which will corrode pretty fast. Blackwolf uses cap screws on his which I believe will remove the problem. |
20th Jun 2019 8:26pm |
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 826 |
These are blindo’s with 255/85r16 toyo mt’s. They are the et15 ones so have slightly more offset.
Click image to enlarge Click image to enlarge Click image to enlarge |
21st Jun 2019 5:31am |
Cont.... so if yours are the wider offset ones you may find you don’t need a spacer
21st Jun 2019 5:36am |
