Home > Maintenance & Modifications > Td5 fuel pump replacement
LandRoversofLondon
The fuel pump on my Td5 has packed up and needs replacing. I’ve been quoted £650 to get it replaced, is this the going rate for a job like this? I’m against cutting a hole in the floor which I know would be cheaper! Instagram @LandRoversofLondon
www.instagram.com/landroversoflondon
Post #777439 14th Jun 2019 9:15am
If it is a main dealer quote that is probably cheap, given that a new genuine fuel pump is around £330 and labour will be around £100 per man-hour.
Post #777440 14th Jun 2019 9:33am
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Mine died last year and was replaced with a genuine unit by a local indy and the bill was near £1K, so £650 sounds quite cheap by comparison.
Post #777441 14th Jun 2019 9:35am
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
I paid £700 inc genuine part , so I sounds fine👍🏻 2002 td5 90 county hardtop
Post #777470 14th Jun 2019 2:00pm
Get a discovery pump.... exactly the same as defender bar the float arm, which unclips from both types.
disco one is (well, was a few years back) substantially cheaper.
Post #777484 14th Jun 2019 4:24pm
TJH1985
I fitted a Valeo OEM pump to mine and it was still £200!
I didn’t cut any holes etc, it wasn’t that much work to drop the tank.
Post #777485 14th Jun 2019 4:41pm
leeds
Just be aware that the fuel line connectors on a TD5 can be fragile.
If the plastic connectors break choices are new fuel lines from LR at about £250 or a set of replacement fuel line connectors
Brendan
Post #777490 14th Jun 2019 4:59pm
miker
About £50 cheaper for the VDO disco once to the VDO defender one currently, still both quite painful at over £200 Big Cry
Post #777952 18th Jun 2019 6:04am
geobloke
Brendan
Too right... This is the main reason for not dropping the whole tank and doing the inspection hatch in the floor modification. From experience, so very fragile.
I ended up with a Bearmach pump as it was the only one I could get next day. It works well, but is good lord it is much MUCH noisier than the VDO unit I took out.
Post #779048 26th Jun 2019 7:59am
miker
I have a replacement pump in my boot currently, awaiting me to have some spare time, or complete failure of the fitted one! Current trick is it won't start when the tank is less than 1/3rd full unless I run a purge cycle first.
Still haven't decided whether to drop the tank or cut the hole though, how have people repaired the hole afterwards?
Post #779052 26th Jun 2019 8:06am
excossack
Mine is similar, if less that 1/4 of a tank it starts, then cuts out unless I have my foot to the floor and then the engine pulls through and works fine. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #779060 26th Jun 2019 8:31am
dorsetsmith
Replacement fuel line connectors kit Thumbs Up home engineered works treat
Post #779069 26th Jun 2019 9:21am
Boyd
France 2003 Defender 110 Td5 SW Zambezi Silver
Shocked Thumbs Up
Any hints and tips appreciated, as i'm just going down this road and am struggling to find replacement connectors or pipe joiners that are cheaper than the Nakatanenga £36?!
Anything appreciated Mr. Green 2003 Zambezi Silver TD5 110 XS SW overland prepped....
2004 Santorini Black TD5 110 XS SW left hooker for sale!
2004 Alpine White TD5 110 left hooker (work in progress)
Post #804574 3rd Dec 2019 11:14am
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
Did you find a cheaper source for these connectors?
Patrick
Post #859021 30th Sep 2020 7:47pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
I did a hole during lockdown.
Fuel pump doesn’t need replacing yet but it’s 20years old so I thought while I had the time I’d get it ready so it’s an easy job when it comes
Post #859028 30th Sep 2020 8:38pm
