Home > Maintenance & Modifications > Terrafirma NAS Bar fitting instructions
tyrannosauROSS
United Kingdom 2006 Defender 110 Td5 CSW Chawton White
Hello and good evening,
I don't suppose anyone can find the fitting instructions for a terrafirma NAS rear step can they? Ive had one in the garage for months now and I have gone to fit it, but there's no instructions.
Thanks
Ross
Post #777246 12th Jun 2019 6:58pm
LCJ
I know it says Britpart but I’ve got a terrafirma one and it’s exactly the same: https://www.paddockspares.com/downloads/STC50301_vr1.pdf
Post #777252 12th Jun 2019 7:31pm
tyrannosauROSS
Thanks.
These are identical to the ones I found on extreme 4x4's website. I think I have it in now, except the two 120mm bolts, which in my kit are 130mm and guess what?, they are 10mm too long!!
Now I need to go and buy some that are the right size, I dont want to cut them down because the are BZP.
Grrrr.... nothing ever fits first time!
I also have in my kit 2x T shaped pieces that have two holes drilled in them. I can't find them mentioned in the instructions anywhere.
Post #777276 12th Jun 2019 8:20pm
OJ
Scotland 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
The T shaped bits fit inside the crossmember at each outer end where the bolts attach, stops the crossmember distorting when you tighten the bolts up, the T part helps you locate it, check if you have two heavy spacers that fit onto the long bolts that take up the extra 10mm
OJ
Post #777862 17th Jun 2019 3:19pm
