![]() | Home > Td5 > Gears |
Ndamico Member Since: 03 Apr 2019 Location: Canada Posts: 52 ![]() ![]() ![]() |
Hi,
My TD5 currently has stock 3.54 gears. going from stock to 35" tires and lockers. i've been looking at ashcroft's gear calculator here: https://www.ashcroft-transmissions.co.uk/calc/ratio_calc.html on my gasser v8 RRC with 1.2 transfer boxes i always went 4.12 or 4.75.. however with the storm tuned td5 and 1.4 transfer box it seems like even 4.12 would be too low of a gear for 35" tires. what do most of you do when you go to bigger tires? thanks |
thanks for the reply. what do you find you can cruise at on the highway?
i see you have a 2007 110. are you still using the stock gears in the p38 diff or did you switch to the ashcroft 3.54 gears? i keep reading the p38 diff is weak and i should switch it for sals..
Mr Fudge Member Since: 05 Dec 2013 Location: Near Oxford Posts: 90 ![]() ![]() |
Profiles out of date
![]() My comments are for 2001 TD5 90. Comfortable cruising speed is 65mph to 70mph. I also have an overdrive which I can use on the level and downhill if I'm doing over 65mph. |
what seems to be the max highway RPM you like to run that thing at? i'm surprised you have an overdrive with stock gears?
