Home > Maintenance & Modifications > Prop shaft noise and play |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20572 |
You really need the prop off to check the UJ's properly, but it maybe spline wear on the slider in your case.
If you do check slider wear make sure you don't pull it out all together if you can without a reference mark and much the same should be done with each end to the diff flanges so everything goes back as it should. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 Last edited by custom90 on 10th Jun 2019 6:20pm. Edited 1 time in total |
10th Jun 2019 4:45pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17536 |
Wear at that point cannot be repaired and a new propshaft is the only answer. The wear will be caused by a failure to grease the shaft.
10th Jun 2019 5:40pm |
Ra13579 Member Since: 07 Jul 2018 Location: Milan Posts: 11 |
Ok great I’ll try this to see what I come across. It would be nice if it was just the UJ but I won’t get my hopes up too soon. It’s a good starting point! |
10th Jun 2019 8:30pm |
I was thinking that it was lack of grease in there, I greased the UJs but to be honest I am not really sure you can grease the prop shaft where I am having the problem. I believe on the older models you could but not on the newer, if you could help me out by pointing me where to do it that would be great. Cheers |
10th Jun 2019 8:33pm |
