Home > Maintenance & Modifications > 110 prop shaft.
L110CDL
110 prop shaft.
Hi All
I have noticed a vibration when accelerating up the gears and more noticeable when going up hill, so my thinking is that one of the UJ's is on it's way out, this is based on when i grease the nipples on the propshaft that the grease does not come out all of the joints, it only comes out on one side, so my thinking is that as i can't take a chance that if i take the propshaft off, it's going to be an easy fix to change the UJ's, yes i know i'm dreaming Laughing
So i'm thinking of getting another propshaft to put on , then i have no worries about the time issue to put it back on sooner rather than later Thumbs Up
If i was to get a new one, i can keep that one on and then use mine as a spare when the UJ's go again, so do i by brand new, if so which is best for Millie Question
Buy a used one Neutral
Or Question
I am trying to do more stuff like this myself as i read very inspirational threads
Many thanks for looking Thumbs Up Clayton.
Keeper.
Post #776558 7th Jun 2019 7:22pm
Hardy Soicer seems to be pretty reliable, I think this maybe Genuine anyway.
I have GKN UJ's on mine, I believe the two companies may have now merged unless it's my imagination.
Don't forget you can run in 2WD with the diff locked if need be like I did last year, but not ideal if you have to travel far or with loads etc. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #776570 7th Jun 2019 7:46pm
L110CDL
Thanks Steve and yes i have had to use the diff lock when my front propshaft decided to go awol Rolling Eyes Clayton.
Keeper.
Post #776575 7th Jun 2019 7:53pm
A new, aftermarket rear prop from the likes of Paddocks is about Β£115. Give that sort of price, I'd buy and fit one of them and then refurb your existing one at your leisure. Darren
Post #776612 7th Jun 2019 11:00pm
sako243
UJs with a big G clamp, big enough vice or hydraulic press are easy enough to do. Ironically the last time I had to do it I was at the other end of the county to my 80 tonne press Sad so made do with big clamps Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #776633 8th Jun 2019 6:36am
landy andy
If you want a replacement and/or parts, or yours reconditioned talk to bailey Morris props.
http://baileymorris.co.uk/Home
Very nice helpful people.
Andy.
Post #776634 8th Jun 2019 6:39am
^^^^ Anyone done their own UJ’s and then got them balanced again? TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #776676 8th Jun 2019 12:17pm
sako243
You shouldn't need to balance them after doing UJs. It's the prop that is balanced and provided you don't cock up the phasing of the splines in the prop itself not much to go wrong. Ed
Post #776677 8th Jun 2019 12:31pm
The LR weight assembly though has a lot to be desired, I was wondering if they could be thrown of balance out over time. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #776682 8th Jun 2019 1:54pm
sako243
Not on mine. It's a plate welded plenty strongly enough to the prop... The rear I can't comment on since I gave my rear prop to Retroanaconda when I swapped it for a short nose pegged Ashlocker and got a Gwyn Lewis one because of the different length. Ed
Post #776687 8th Jun 2019 1:59pm
L110CDL
Thank you to all above Thumbs Up Clayton.
Keeper.
Post #776978 10th Jun 2019 8:47pm
Typical JLR quality of recent years Shocked
Post #777004 11th Jun 2019 7:17am
I wonder what a place like Bailey Morris would charge for a prop shaft re balance? I presume they'd do that a place like that. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #777055 11th Jun 2019 1:09pm
