![]() | Home > Puma (Tdci) > Roof gap too A pillar |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3656 ![]() ![]() ![]() |
its meccano there are a series fasteners holding the roof on, drop the headlining and tighten them up DEFENDER 90 TDCI XS,
I hope everyone is well and your land rovers make you happy Last edited by LR90XS2011 on 8th Jun 2019 6:23am. Edited 1 time in total |
double post DEFENDER 90 TDCI XS,
I hope everyone is well and your land rovers make you happy Last edited by LR90XS2011 on 8th Jun 2019 6:22am. Edited 1 time in total |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
In the corners are screws that have a habit of working loose. Refit with a bit of silicone on the thread and they shouldn't loosen off again.
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1822 ![]() ![]() ![]() |
There's a row of bolts holding the roof to the frame under the headlining, I'd carefully slacken them all a little, clean the joint with a cloth and some meths, squeeze a line of black silicone sealer in then re tighten and clean off excess sealer. The silicone will help eliminate leaks forming and should stop the bolts loosening again.
Check the bolts have shake proof washers fitted as well, good luck. Keith |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5811 ![]() ![]() |
Agree with above but DON’T use silicone sealer. Use a PU sealer such as sikaflex or tiger seal. Silicone want last and will effect any future paint work you have done. PU sealer will also have a much better grip on the metal.
Andy. |
Roba71 Member Since: 07 Jun 2019 Location: Rangiora Posts: 16 ![]() ![]() ![]() |
Thanks for all the replys everyone.
We only purchased the 110 today in a private sale and didn't notice this until we headed down a gravel road and noticed the knocking. Previous owner denied all knowledge of it. My fault for not spotting it, lesson learned. But again thanks for the fast replys, were disappointed, but now looking forward to getting it sorted and getting it dirty !! |
