Home > Technical > HELP with immobiliser/battery issue |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 |
It sounds as though the battery’s gone in your fob . Pop a new one in and see if it makes a difference .
Mine has also been playing up for the past month then wouldn’t start altogether two days ago, new battery fixed it straight away ! I can’t remember the penny battery number other than it ends in a “32” https://www.instagram.com/hustynminepark/ |
6th Jun 2019 10:49pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
CR2032
7th Jun 2019 4:55am |
That sounds like the main battery is flat. There have been several similar instances reported on here, where the battery has got so low that trying to start the engine drops the voltage enough to kick in the BBUS. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
7th Jun 2019 6:38am |
Lew-M Member Since: 04 Apr 2016 Location: North West Posts: 95 |
Thanks for the replies guys,
I have recently (in the last 6 months) changed the fob batteries as the range on them seemed very poor, so surely these wouldn't be depleted already? The main battery is reading 12.6v currently, so should have enough to start, is there a way of resetting the immobiliser at all apart from the EKA code route? Cheers, Lew |
7th Jun 2019 7:11am |
The only other way would be with a decent diagnostic tool. However, despite the static battery voltage, I still see that as the prime suspect as all of the symptoms you describe point that way.
The BBUS is a simple affair and it's only activated when it detects that the battery has been disconnected (or is flat). Have you got a set of jump leads, as that would be an easy way to prove it or otherwise? Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
7th Jun 2019 7:59am |
