![]() | Home > Td5 > TD5 Rear wiper motor wiring - different connectors |
Can you post some pictures of what you've got? Darren
Not Mr Smith Member Since: 04 Feb 2019 Location: Leeds Posts: 10 ![]() ![]() ![]() |
Here we go - the wonders of modern technology.
1st pic is the new, others are the existing and should hopefully show the wiring ok. |
Yeah it’d help if I attached em in the first place
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
I'm not quite sure how but you've got the wrong part. That motor is for a post 2012 vehicle. However, the diagrams that I've found, whilst identifying two different motors - pre and post '12 - both seem to have the same part number, which is odd. I can only suggest going back to your supplier, I'm afraid. Darren
Thanks for that - I’ve realised the pic on the sellers website is the same as the original that’s fitted so it looks like I’ve been sent the wrong one. I know what you mean about the part number, it’s got me confused🥴
And randomly when plugged in, the new wiper works. It means that the black wire to the smaller connector (the one on the back of the smaller two pin plug) doesn't now connect to anything. I know I'm being an absolute plum but what does this mean? Is the black wire the earth? Cheers!
Yes, the black wire is earth. How have you plugged it in? Didn't you say it had different connectors?
Assuming you've connected it without issue, it's possible that the internal wiring has been changed so as not to require a separate earth, which probably explains the part number matching, too. It's either earthed through the casing or it somehow uses the other switched earth to serve both functions. Anyway, if it works as expected then I'd take that as a win. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Stupidity on my part to be fair re the connectors, I thought they were different - the only actual difference is that the smaller plug/connector at the rear of the original has the additional wire but they connect to the new one just fine. I'll pay attention next time before posting.......
![]() Thanks again for your thoughts, I'll fit the part tonight and that should be it. Headlining re-trim next and thinking about new door cards all round at some point. |
Fair enough
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
