Home > Puma (Tdci) > Battling 1103 error and loss of power
expatRob
Germany 2007 Defender 110 Puma 2.4 SW Tonga Green
I have two things happening and maybe they are related. I get the MIL indicator and the only error is 1103. I have replaced the MAF sensor and I am getting a scoop to mount to try and get more air flow to see if that helps.
This doesn't happen all the time and mostly when it is cold outside.
While I am driving on the highway at speed and the then the engine loses power and the 6th is worthless, I pull to a stop, turn off the engine and then turn back on. It fixes the problem. Obviously I can't just do this all the time, I need to find out what to do.
Are these two things related? Is my Turbo the problem, for example maybe it is sticking.
Thanks for your thoughts.
Rob
Post #776014 3rd Jun 2019 8:34am
Martin
Site Admin
Check the wiring loom to the sensor for damage.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #776016 3rd Jun 2019 9:00am
neon1991
United Kingdom 2014 Defender 110 Puma 2.4 USW Firenze Red
it's weird that it's restricting power. my 2.4 gave this code a couple of times, swapped the MAF and still threw up the code. swapped the EGR and it didnt come back. I wasnt getting any power loss though. The only time I had power loss was when I had a duff battery and my diognostic thing said it I had an over boost problem. Restarted the car and it was gone.
Post #776070 3rd Jun 2019 4:12pm
PAT303
Australia 1998 Defender 110 300 Tdi SW Alpine White
Remove the boost control sensor and clean it with MAF cleaner, that will fix your problem.
Post #776259 5th Jun 2019 9:56am
ickle
Or turbo vanes sticking…….
Post #776316 5th Jun 2019 5:45pm
