Home > Technical > Wading depth
AdrianCR
2016 Defender 110 Puma 2.4 XS CSW Scotia Grey
Wading depth
Regards.
I have always wondered, what is the limitation of a DEFENDER to have a wading capacity from just 500mm. Compared to a Range Rover for example, being much more technological and a wading capacity of almost double. 900mm.
thanks.!
Post #774589 23rd May 2019 7:22pm
Huttopia
A Defender will wade to more than 500mm, you just get wet feet, knees, arse, depending how deep you go. 😂
Post #774593 23rd May 2019 7:27pm
DSC-off
I suspect it's the breathers for axles, engine and gearbox. With very little extra preparation the defender can go a lot deeper than 500mm.
Post #774595 23rd May 2019 7:33pm
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Air intake on the wing, hence snorkels are so popular.
Post #774598 23rd May 2019 7:47pm
seriesonenut
This looks deep enough....... Whistle
 1984 One-Ten CSW
2010 XS USW (sold)
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #774599 23rd May 2019 7:53pm
Piggle
2003 Defender 90 2.5 TD XS CSW Bonatti Grey
And for the td5 you have to consider the location of the ecu in the seat box. Fairly easy to relocate to a higher position I believe. Presumably the same for the puma.
Post #774650 24th May 2019 8:08am
landy andy
Td5.
Just drive it properly. Get a bow wave, and don’t hang about. Never caused an issue with any of my electrics.
Post #774653 24th May 2019 8:17am
dorsetsmith
If you the relocate ECU on TD5. Puma 2.4 - TD5 under driver seat fuse boxes and relays. ABS controller too Whistle
Post #774656 24th May 2019 8:47am
The ECU on the TDCi is on the bulkhead behind the engine at cylinder head level and is actually quite well protected.
I have had my Puma in a ford deep enough to have water over the front wings and up to the door handles on the upstream (driver's) side. The only ill-effect was that the carpets got very wet, however it would have been different without an RAI since the original wing-side air intake was underwater.
As landy andy says, if you know what you are doing you are unlikely to have any issues unless you are a complete nutter.
I did one manage to fill my wellies whilst driving my S1 80" through a flood, the water inside the cab was just over the level of the seatbox. Even though it was completely standard and has a petrol engine with spark ignition and a mechanical fan, it caused no problems whatsoever (except to my socks) because the vehicle was properly set up. The distributor on the 1600 and 1997cc engine is right at the top, and the fan belt slips when wet if properly adjusted. The bow wave keeps the level in the engine bay about 18" lower than the level ahead of the vehicle.
Post #774660 24th May 2019 8:56am
geostrategist
United Kingdom 2008 Defender 110 Puma 2.4 CSW Tonga Green
I thought I’d bump this thread as it’s a bit topical at the moment.
I was all set to take my 2.4 TDCi thogh our local ford flooded to 3’’ / 900mm, and was wondering what the limit was. In the end it was blocked by a stalled car and van, so no chance to find out.
Post #802563 17th Nov 2019 1:46pm
j17
This was a great vid I watched
He went through 1.2m!
[/url]
Post #802630 17th Nov 2019 10:58pm
seriesonenut
Nothing like a salt water bath to accelerate the corrosion of a chassis and everything else! The on line MOT history for the 90 looks interesting Whistle 1984 One-Ten CSW
2010 XS USW (sold)
Post #802632 17th Nov 2019 11:07pm
Three feet of water shouldn't be a problem in a standard Defender as long as you know what you are doing, but equally it is deep enough to do serious harm if you don't, or if it is fast-flowing.
Post #802643 18th Nov 2019 12:10am
HardCharger
Also remember that your alternator is mounted quite low in the engine bay. If you do any deep water fording, please remember to dry out the alternator by keeping the engine running a bit before shutting the vehicle off. Otherwise, you may damage or seize the bearing and screw up the IC
Post #802653 18th Nov 2019 3:35am
