Home > Td5 > Down on power/not boosting...
Paul1275s
United Kingdom 2003 Defender 110 Td5 SW Belize Green
TD5 220k on it, replaced exhaust manifold, new MAF fitted. Wastegate appears to be free moving, new injector harness.
It seems to run ok after disconnecting the battery but then loses power again after a time. Starts instantly hot or cold. Doesn’t smoke excessively. Any prime suspects? It doesn’t seem to make much difference when MAF is disconnected, was an eBay special MAF sensor. 2003 Defender 110 TD5 SW
2003 Caterham 7
2006 Mini Cooper GP
Post #774470 22nd May 2019 9:27pm
Paul1275s
Ok, gonna check red ecu plug and look at cat. 2003 Defender 110 TD5 SW
2003 Caterham 7
2006 Mini Cooper GP
Post #774529 23rd May 2019 10:15am
lightning
The engine should run OK with the MAF unit disconnected, it won’t be at its best but will perform fairly well (my 110 TD5 will still do 70mph)
Post #774552 23rd May 2019 1:54pm
fred1922
Australia 2000 Defender 130 Td5 HCPU Alaska White
It is difficult to see if wastegate shaft is moving without removing cover guard, two pop rivets. If car had been unused for some time, it would certainly be worth more attention.
Post #774635 24th May 2019 12:09am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
What fuel pressure are you getting? Mine was dog slow and wouldnt boost when the high pressure stage of the fuel pump died. When was the fuel filter last changed? 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #774843 25th May 2019 10:45am
Paul1275s
Not sure how to measure, I assume I'd have to take it to a garage? I'd imagine the filter is way overdue going on the rest of the previous maintenance! Red plug was full of oil, I've given it a damn good wash out with electrolube, I think it'll need a few more goes... 2003 Defender 110 TD5 SW
2003 Caterham 7
2006 Mini Cooper GP
Post #774845 25th May 2019 10:50am
landy andy
Good call on fuel filter.
Start with the easy stuff first. Air and fuel filter.
Post #774847 25th May 2019 11:05am
michaelwl
South Africa 2002 Defender 110 Td5 SW Alpine White
If the red plug has oil in it, then you should chance the injector harness as that's were it leaks from, and also clean out the whole loom from the harness down to the red plug. 2002 110 TD5 White
1981 S3 R6 Matt Green - Now used as game viewer
2013 Discovery 4 XS
Post #774850 25th May 2019 11:27am
