![]() | Home > For Sale & Wanted > Sorted 110 aluminium roof rack, Hannibal, patriot etc |
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 725 ![]() ![]() ![]() |
Hi there, after an aluminium roof rack for my 130, needn’t be pristine as will most likely be altered a bit to fit the box body..
Hannibal preferred as I’ve 2 Hannibal awnings to clamp on.. Cash waiting, no messing, will travel , gsoh etc etc!.. Cheers alex 98 300 tdi 90 project 94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility Last edited by alwoodley72 on 19th May 2019 10:42pm. Edited 1 time in total |
kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 277 ![]() ![]() ![]() |
Got one for a 110 sat on the floor by my shed....
60th anniversary model. Tony |
Hi tony,,thanks wwhaat does is look like/cost?
Cheers Alex 98 300 tdi 90 project 94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Hi Alex It's painted silver by the factory which is how they released the 60th anniversary models. Shows signs of where water has got under the lacquer so would benefit from a spruce up. I'm asking £500 which, I think, is quite cheap - a couple of hundred quid on paint would produce a rack worth over a grand going by what I've seen. I have no interest in painting it though as it's a bit in the way so just want rid of it. So, it's a full 110 Hannibal rack for a station wagon. Has the ladder and rails (removable). The support brackets for the rails have 60th anniversary badges printed on them rather than the usual Hannibal badge (although there is a full set of those as well which I'll include) Cheers Tony |
Hi tony, looks good..
I fear that distance may make this an impractical buy for me, unless you are planning a trip ‘daarn saarf’ anytime? I’ve a sniff on a patriot 130 rack that’s a lot closer to me, I’ll let you know when he gets back to me.. Cheers again Alex 98 300 tdi 90 project 94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility |
Hi Alex
I'll be heading down to Dover the second week of June so we could perhaps do a meet up part way if that suits. I'd need a firm commitment to buy though as I'll be on my way to have a pop-top fitted so wouldn't be able to keep the roof rack on! Tony |
Hi tony, obliged, still trying to decide which way to go, I’ll let you know ASAP..
Cheers alex 98 300 tdi 90 project 94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility |
Well, did a late night trip up to Thame and picked up this little(!) as new beauty for £700
![]() Click image to enlarge Put my Hannibal 270 awning on in the rain, as you do... ![]() Click image to enlarge Just need to sort a proper rear support and fix on my lights, tube carrier, other awning.. ![]() Click image to enlarge Bit more slick than the utility rack it replaces ![]() Click image to enlarge Didn’t come off without a fight!!… Cheers Alex 98 300 tdi 90 project 94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility |
