Home > Maintenance & Modifications > Alive Silicone Boost Hoses
Landborgini
United Kingdom 2014 Defender 110 Puma 2.2 HT Corris Grey
Recently purchased a 14 plate RHD 110 and it has an ECU map to 180hp with a upgraded intercooler. Over the last month, firstly the intercooler pipe disconnected from the turbo and now it’s split underneath just above the steering arm.
I have received the pipes from Alive and have no idea where the small elbow goes with different apertures either end. The pipe that goes on the near side is pretty obvious and the off side pipe looks like it will fit as it has an elbow already on the turbo end.
Please put me out of my misery as it’s a bit embarrassing driving in limp mode.
Where does this small elbow go !!
Thanks in advance
Mark
Post #773755 18th May 2019 8:09pm
Roy5695
Goes down by the EGR. As you’re looking into the engine bay, right side, under all the water pipes. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #773768 18th May 2019 9:02pm
