Home > Puma (Tdci) > Not good news!
churchy
2007 Defender 110 Puma 2.4 XS CSW Java Black
Not good news!
Morning all,
I’m after rational opinion!
The wagon has been in the garage since Wednesday at a well respected Land Rover independant. Diagnosis pointed to 2 knackered injectors and two not far off being knackered. All four replaced but yesterday I was advised that the engine is very much down on compression and smoking horribly. Have been told to expect a terminal diagnosis.
I therefore have a big decision to make as being self employed I need a largish wagon for work to transport tools etc and with current workload the timing could not have been worse.
I obviously already have a large bill for repairs to date but still no working vehicle.
Although its done 199,500 miles bodywork, interior and chassis its in very good condition and is regularly complemented. New Clutchfix system fitted about 5k ago. My plan over the next few months was to prep it up for storage and put it away for safe keeping as I don’t really want to see it go however I now maybe have to make a different decision!
- do I get the garage to take the engine apart and dig deeper? More expense but not necessarily a cure.
- if it is terminal do I shell out for a replacement engine?
- do I accept its gone and sell as a non runner as is?
I have no idea what it would be worth as is and am struggling to make a rational decision!!!!!!
2007, CSW, TDCI XS
Gutted but would welcome advice!
Churchy
Post #773492 17th May 2019 6:57am
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Churchy, if your plan was to put it into storage soon anyway, why not bring that forward and do it now? Gives you time to decide which way to proceed and gather quotes/build up funds to make the necessary repairs. 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #773503 17th May 2019 7:35am
lohr500
If you really want to keep it and your plan was to put it into storage anyway, why not do that with the poorly engine.
And then search for a replacement engine at the right price in your own time.
Then pick up a cheap set of wheels to transport your tools etc.
Post #773505 17th May 2019 7:37am
Martin
Site Admin
If you do want to sell as-is let me know, I'd be interested Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #773513 17th May 2019 8:27am
Stacey007
Wasn't there some engines for sale around £2500?
Seems to make more sense if the rest of the truck is ok to fit a new engine? otherwise your chasing problems?
You say you were going to store it away so guess you don't require the cash out of it for now?
Could you cope with a Transit type van or large cheap estate for now for now until its sorted.
Post #773514 17th May 2019 8:29am
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Speak to these guys who specialise in the transit engines: C&F engineering 01462 851100.
They are the most knowledgeable guys I know and do
reconditioned ones.
Post #773516 17th May 2019 8:50am
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
Seems to me like they need to tell you whats causing the low compression.
Several things
bent or stuck valve
leaking pistons
worn out valve train ( this would give low compression across all cylinders) so that give you a clue.
How low is the compression in each cylinder?
They can check all of the above with a pressure test ( which i assume they have already done) and a leakage test with compressed air all without having to strip the engine down. It will tell you if its head related or something deeper in the block.
Never had to do it with the defender, but i always , use engine machine shops tucked away on the industrial estate, find one of those and go and have a chat.
Pop it in your garage and work out a strategy in your own time.
There are loads of transits around that dont meet the euro 6 legislation so cheap assuming you dont need euro 6!
Sounds like you have a good gearbox and defender, so its a shame to let a leaky engine ruin your plans.
Post #773518 17th May 2019 9:02am
kaney
United Kingdom 2005 Defender 90 Td5 CSW Epsom Green
Now this might sound stupid but if it's going to go into storage why don't you ask a collage or university if they want to do a engine rebuild protect
You obviously pay for any materials but insist on the tutor being there for the work being done
We have to keep students busy learning about this stuff and may get some young landrover defender enthusiasm coming through
Post #773523 17th May 2019 9:26am
I would whip the head off to establish the reason for the low compression. Removing the cylinder head should not take long nor be expensive, and will almost certainly reveal the problem. You will then know whether that engine is salvageable or is scrap.
If you were planning to store the vehicle for a while then do that, but at least you'd know whether you need to find a new or reconditioned engine or whether it is more sensible to rebuild the original. You can plan this and/or do this whilst the vehicle is stored.
Your options, I suggest, are either to recondition your current engine, buy a brand new engine, or buy a salvaged engine from a scrapped vehicle which you could use as is or rebuild. You really can't decide on the most sensible option though unless you know what is wrong with the old one and whether or not it is rebuildable or exchangeable.
If you want a Defender long term, and are happy with the one you have (apart from the engine), then if I were you I would stick with the vehicle I know rather than sell it and buy another.
Post #773529 17th May 2019 9:44am
diduan
Bulgaria
I have rebuild my transit engine once, so i do not want to do this again. Here is an interesting writeup if you want to swap the bullet proof 4.0 AMC inline 6. Very Happy Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt
Post #773560 17th May 2019 12:40pm
diduan
Bulgaria
https://www.landyzone.co.uk/land-rover/jeep-4-0-engine.278357/ Defender 110 SW MY2011 2.4tdci decat, no EGR
Post #773561 17th May 2019 12:40pm
Caterham
/\ Thumbs Up
Post #773563 17th May 2019 12:53pm
landy andy
If you can afford too, store it, and look into fitting a different type of engine. If not get rid now and buy the vehicle your business needs.
Post #773564 17th May 2019 1:06pm
churchy
Thanks all for the sound advice - I knew I could rely on you!
Having slept on it - I am going with what was in my mind I think which is to keep it and store it (I need to find storage which is the next task - not quite enough room at home to keep it there) and bring forward my purchase of hopefully a T5 4motion. I am too attached to the wagon and it was always bought with a mind to keeping whatever it threw at me. I will however bear you mind Martin! However not quite sure how I would put a figure one what it may be worth in current condition?!
I have this morning instructed some further investigation to hopefully give me a more definitive diagnosis which as you guys have said will make the plan of attack more strategic.
Once I know more I will update if you guys don’t mind and probably also ask for a check list of things to do before tucking it away.
Thanks again for your advice - I know there are more important things going on in the world and at the end of the day its just a lump of metal - but as you all know they get under your skin and become much more than that!
Post #773617 17th May 2019 6:50pm
Slideywindows
Maybe it isn't just a lump of metal.
Once you have owned it long enough and once it has shared enough of life's experience with you, it becomes a friend.
And friends are not always perfect. Wink
Post #773711 18th May 2019 12:08pm
