![]() | Home > Technical > Td5 crank sensor o ring part no? |
O ring is part of the crank sensor build no part number
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 545 ![]() ![]() |
Use the one off the one you take out when you replace it. Or take it out and measure it and order from one of the many suppliers on the net.
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 ![]() ![]() ![]() |
Is the metal plate NSJ000010 what you mean? I have a both the sensor and NSJ000010 in unopened packages and I don't see any rubber O ring.
J Antares Treadwell, a MY06 110 Td5 in Chawton White |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2205 ![]() ![]() ![]() |
Buy a pack of quality nitrile orings. One will fit
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 ![]() ![]() ![]() |
Well interestingly I’ve been looking into it and none of the genuine ones have one but most of the aftermarket ones do.
So makes sense that my genuine one doesn’t. The green o ring on the aftermarket one vs the slot on the genuine pictured ![]() Click image to enlarge ![]() Click image to enlarge |
Why would an O ring actually be necessary there? Antares Treadwell, a MY06 110 Td5 in Chawton White
michaelwl Member Since: 19 Nov 2014 Location: Durban Posts: 65 ![]() ![]() ![]() |
I've just bought a genuine one from a LR dealership here in South Africa and mine came with the o-ring already fitted. 2002 110 TD5 White 1981 S3 R6 Matt Green - Now used as game viewer 2013 Discovery 4 XS |
