Home > Puma (Tdci) > Headliner fixings
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Headliner fixings
I know the headliner uses the small firtree fittings into the roof framework. I'm just about to remove the front section above the driver in a 2010 Tdci 110. It has fixings around the edge. Are these the same firtree fittings as the rear headliner before I break them all during removal Smile
Post #772917 13th May 2019 11:29am
Yes. Darren
Post #772918 13th May 2019 11:31am
boxoftricks
Perfect thanks
Post #772919 13th May 2019 11:32am
X4CAC
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
I've just started the exact same job Thumbs Up
I've removed the rear 2 sections so far in my 90 and only managed to keep 2 of the fir tree clips in tact, the others are all brittle and have come out in pieces. One top tip I was given at the weekend is when buying the replacement fir trees stick to genuine as sometimes the aftermarket ones are often slightly shorter and don't fit properly.
Post #772925 13th May 2019 11:50am
