![]() | Home > Maintenance & Modifications > Rear axle lower shock bushes |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17598 ![]() ![]() ![]() |
Yes, they should. They wear very quickly, and I have found that sometimes it is helpful to add a penny washer on either side of the mount (put the washers between the two rubbers, not on the outside of the rubbers). This effectively thickens the mount and seems to improve the situation. It also can't be seen at MOT time so it doesn't look as though you're trying to mask defective rubbers.
