Home > Puma (Tdci) > 2011 90 2.2 pickup clutch woes sorted at last. |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2296 |
What a swine. Did you upgrade to the heavy duty thrust bearing? > 110 XS Double Cab
8th May 2019 9:59am |
Leroy Member Since: 20 Nov 2018 Location: Western Highlands Posts: 15 |
Left the judgement to my mechanic, who seems to know his stuff and likes Deaffies, and he deals with parts suppliers who guarantee covering the cost of any part failure repair, including diagnosis and labour. I also only intend using the machine as mostly a low useage tarmac toy, so I figured that driven properly it'll last me well past my own use by date.
8th May 2019 10:07am |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 747 |
I recently got a great tip on driving the defender to protect and extend the life of mechanicals as they are not built with the same refinement and tolerances as modern vehicles.
The advice was when you change gear fully depress the clutch, change gear carefully (not slam from one to another), fully release the clutch and only then press the accelerator. This gives the gear and transfer box and drive train that critical few milliseconds to properly engage. Not to feather in the accelerator as you come off the clutch. I've been doing this and it has got rid of a lot of the clonks and clanks I previously heard. |
8th May 2019 10:39am |
Must practice that technique. Though I'm still coming to terms with just driving a manual car at all again, after years of lounging back in autos and letting it all happen via God's grace and the position of the loud pedal. I'm getting much better at remembering to change down for intersections and roundabouts in Tonka now, after some embarrassing kangaroo impersonations over my first few weeks.
Fortunately early training over many years in the dim past, in a succession of Morrie Minors and Hillmans has helped rejuvenate the muscle memories, plus a stint in Toyota Landcruiser volunteer bushfire response units back in Oz. |
8th May 2019 3:51pm |
Yep, it takes a while with conscious thought. Nothing wrong with kangarooing straight over the top of a roundabout showboating your off-road prowess
8th May 2019 4:14pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17367 |
How else would you change gear? There must be some seriously inept drivers out there! It also helps if you double-declutch, especially down-changes. |
8th May 2019 4:42pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3274 |
Beat me to it. |
8th May 2019 4:43pm |
I assume the key point is the careful timing of the fast pedal. Not sure if I can estimate a millisecond, though.
Used to know how to double declutch many yrs ago (in Oz we called it double shuffle, which rolls off the tongue a bit easier). Long lost skill now, but will start practising again. Once I figure out where the ON button for the double de-whatever program is. |
8th May 2019 4:58pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
now where's that emogie with the hand in the air - you know the one that looks like a school kid with his hand in the air 'me sir, me sir' joking aside - I'm not suggesting I'm completely inept BUT I do believe the defender has taken me longer to get used to than anything I've ever owned before and as such do sympathise with others struggling. Personally I've always (so far as I can remember) depressed clutch, released accelerator, changed gear and then blipped accelerator - never had a problem before. Defender on the other hand demands you keep the accelerator depressed and as mentioned before there's skimping on the clutch - fully depress and nice n slowly. |
9th May 2019 7:09am |
