![]() | Home > Maintenance & Modifications > Articulation vs Anti Roll Bar |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2192 ![]() ![]() |
My landy doesnt have any ARBs and i drive 60 - 80 miles a day for work. Country lanes and Mway. Not missed them.
Best comp would be to remove the front, keep the rear. Instagram @defender_ventures Empire Tuning - Agent |
1) No point fitting longer shocks with standard ARBs in place, they are the limiting factor. 2) No, but you will have to drive more cautiously. 3) You would end up with oversteer, due to the front ARB, which makes for interesting driving. 4) The front would be limited by the front ARB and the rear would articulate well. And finally to the 5th question... 5) Look to fit a standard ARB up front and an X-Eng rear ARB at the rear. The X-Eng rear ARB allows for the unlocking of the ARB when you go offroad and providing you have them fitted will allow +5" shocks to be fitted. Plus the road manners are brilliant. I know, I have it fitted to my 110 and wouldn't be without it now. |
Markez79 Member Since: 27 Jun 2018 Location: South West Posts: 201 ![]() |
Many thanks!
With respect to Q5, would I miss the front articulation if I kept the front ARB and replaced the rear with the X-Eng variant? Sounds like it will be a bit lopsided...! Thanks Mark |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
Re: point 3) - Not wishing to start or participate in an argument, and understanding that in theory your assumption of front ARB on its own would induce oversteer, I have recently done exactly that (due to chassis bracket damage) and found no noticeable difference with "normal" driving.
I don't tend to pootle about, do mainly backroads driving and I have a full cage and Hannibal rack yet have not felt its driving or roll characteristics noticeably altered since the rear ARB was removed. What happens under extreme and rapid changes of direction / steering input is not known (Moose test style) but then I tend not to drive in that manner anyway, and i'm not sure how great a Defender is under those circumstances even with the full complement of ARBs. Like I said, not starting an argument, just my own observations. |
Is the front ARB easy to remove? Thanks |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8166 ![]() ![]() ![]() |
I run a 110 and a 90 with just front arbs. Front travel isint massive anyway and works ok with front arb.
Rear travel improved significantly without arb. If you only have one your better with front arb. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Orchard Member Since: 07 May 2015 Location: Usually walking the dog Posts: 258 ![]() |
Regarding the understeer/oversteer chat.
Many things affect this but overall tendency is determined by the balance of roll stiffness front to rear. If nothing else changes increasing the front of roll stiffness (eg a larger dia ARB) will promote greater understeer. So removing it completely will likely generate the opposite effect, oversteer. Vice versa with the rear. This is complex though as on a Defender there is some geometric roll oversteer in rear axle, so less roll angle also reduces that effect. The manufacturers spend years honing and testing all this, so making gross changes like removing just the front ARB will affect the handling in some circumstances, when you least expect it. Take care. 2015 90 XS SW Bowler 1998 TD5 CSW |
The 90/110/130 and Defender models have been supplied with none, rear only and both (the order in which I have also owned them by coincidence).
I'm not sure in the case of the Defender any aspect of them was carefully honed by Land Rover. ![]() |
Tribord Member Since: 20 Apr 2013 Location: France Posts: 220 ![]() ![]() ![]() |
The X-Eng ARB that can be disconnected sounds interesting. When disconnected, what additional articulation do you get with standard suspension? Or do you need to replace springs/shocks to take advantage?
Also how easy/quick is it to disconnect/connect? |
I would like to know this too
I tried to contact Foundry4x4 for more info on the X-Eng Deflex ARB (they appear to be the main supplier), but they do not respond to messages/email/web requests. Does anyone know if there are other suppliers, or alternative ARBs that can easily be disconnected?
I would like to know this as well!
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
If you're just driving "deep ruts and mud" as you say, I don't think losing a bit of articulation will make much difference to be honest.
IMO better to have a slight increase in road going comfort/safety |
Yep, that’s why I’m interested in the X-Eng ARB.....seems best of both worlds.
Thanks |
