![]() | Home > Tdi > Driver's footwell rust |
https://yrmit.co.uk/product/rhs-footwell-r...-defender/
cut out rusty metal work and use repair panel or steel metal and mig weld in new metal prim & finish paint or go too good local land rover specialist get a quote for the work Last edited by dorsetsmith on 30th Apr 2019 4:45pm. Edited 1 time in total |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20651 ![]() ![]() |
^^^^ This as mentioned.
Don't forget corrosion prevention treatment for any seams and the underside also. ![]() For a small part like that you could finish the paint match with an aerosol metallic to match too. Plenty on eBay, if you can find the colour code etc. ![]() ⛽️🛢️⚙️🧰💪 |
AndrewFoxPitt Member Since: 30 Apr 2019 Location: London Posts: 5 ![]() |
Thanks for the advice, so disconnect the pedals and use an angle grinder to cut it out?
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 747 ![]() ![]() ![]() |
Use a cutting disc or suitable fret saw. Be aware what’s on the other side and watch out for sparks igniting anything. Take special note of fuel lines etc.
