![]() | Home > Wheels & Tyres > Cooper v BFG |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
I would Go for the General grabber at2 tyre. Is quieter than the bf’s. Not a popular tyre in the uk but more in Holland. a defender from 1984 pretending to be a puma with a touch of Range Rover
DuncanS Member Since: 06 Dec 2013 Location: Cumbria Posts: 299 ![]() ![]() ![]() |
I must say I do love the BFGs. Very reliable tyres and I've had them on both vehicles I've owned, and every other defender my folks have had over the last 25 years.
The KO2 does skip a bit in damp conditions if you have a lead foot when accelerating out of roundabouts or similar, but nothing a quick bit of Traction Control sorts on the puma. Its fine in heavy rain as I don't tonk it about. I've never really felt it slide at all. North Cumbria Search and Rescue - Team Leader |
Just an after thought.
I don’t know if you ever drive in ie germany in the winter but a snowflake is required there. At the time the bf’s didn’t have the snowflake. a defender from 1984 pretending to be a puma with a touch of Range Rover |
jaygti Member Since: 04 Nov 2012 Location: essex Posts: 387 ![]() ![]() ![]() |
I’ve got the st maxx in a wider size.
It’s very aggressive for a road tyre. I would say it’s half way between a mud and an a/t. I’ve had them for about 4 years and can’t really fault them, on or off road. ![]() Click image to enlarge 2002 td5 90 county hardtop |
The KO2's do have the full snow tyre rating on them, and they perform accordingly as well! North Cumbria Search and Rescue - Team Leader
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
If it's of interest, I've had Michelin Latitude Cross 7.50R16s on my 110 from new and although I never go off tarmac, they've been great in all weather conditions on the road.
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
I run both 265 KO2's and 235 St Maxx, both good tyres, neither can be heard over the wind noise. Coopers are cheaper to buy but I understand probably won't last as long. KO2's do carry the snowflake.
If I had to choose one I would go for the KO2's, but probably just for looks alone ![]() ![]() If you are mostly road use you might consider the Cooper AT3's? Which I understand are very good on the road and surprisingly good off-road. The St Maxx is an agressive lookign tyre. ![]() Click image to enlarge ![]() Click image to enlarge James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Gilloverland Member Since: 12 Nov 2017 Location: Yorkshire Posts: 61 ![]() ![]() |
I've had both and would choose the BFGs everytime - they outlast the coopers by big margin. As for grip in the wet - its a Defender, drive it like one...
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
BFG here as well, and as above if grip is an issue then most of the time the speed is to excessive.
A Defender by nature isn't a sports car, it shouldn't be driven like one. Each to their own but even on road I actually prefer my KM2's to the General Grabber TR's I once had once upon a time. I would seriously consider other tyre types from the same brand. I am however annoyed and dissapointed as of yet the options for sizes they have decided to have. But many manufacturers are just the same. Chillin In The Backwoods🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 923 ![]() ![]() ![]() |
Just over a year since fitment and done about 10K miles and I would say wear is about just under a mm to 1 and this is from mainly tarmac miles.
Cooper states a 14.7 mm tread depth when new for the 235/85R16 so given I'll replace them with about 5mm left. so I've got 9mm of tread to play with and say about 10K a mill then 90K miles isn't what I'll call bad. This is assuming the compound is liner throughout Or I deceide one day to change size as... Whilst they might no longer be as silent as new they still have very little road noise and enough to be drowned out by the windnoise when underway Snow performance I would rate as good and no worse then an older set of BFG AT's Wet road performance is good they handle standing water well and IMHO this is what pushed me to them. Look at the tread and imagine when the water goes when driving is along or diagonal across the tread blocks. The BFG with it's C style interlocking tread might give it some sand traction advantage but water IMHO would be trapped into the blocks rather than dispersed and leading to aquaplaing as the tyre rotates. Offroad the ST - Maxx is great for a tyre with road manners. drop it to about 14psi and it handles well enough that I reckon it outdoes the wranger MTR. Deffo not full MT tyre but handles well enough. My verdict is of an impressive AT that matches the BFG but doesn't cost as much £122 to the BFG £167 each (source 4x4 tyres) so If I was to buy again I would go Cooper. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 ![]() ![]() ![]() |
I favor the BFG myself, having had them on 4 of my Defenders I have just put new 265/16 on at £125.00 each fitted
![]() 2008 SVX 90 2000 XS TD5 90 |
geostrategist Member Since: 25 Apr 2019 Location: UK Posts: 60 ![]() ![]() ![]() |
Thanks guys.
After much deliberation I went with the BFGs. |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 672 ![]() ![]() ![]() |
I have BFG and after about 30k on them I find they regularly lock up in the cold and wet under surprisingly light braking, particularly with a trailer (braked) on. No issues cornering.
I previously had grabber TR which were the opposite. Good braking but poor cornering. I will be trying something different next time, either Cooper AT3 or maybe Nokian Rotiiva AT. |
![]() Click image to enlarge I also sent ‘white out’, but that’s for a different debate |
