Home > Technical > Rear Axle Rebuild - Help
No 6
United Kingdom 1994 Defender 90 300 Tdi CSW Coniston Green
Hi Guys,
I've gone thunk myself into a corner Laughing
I have a 95 MA chassis defender 90 with disc brake rear County (original).
The axle casing is leaking from the weld and someone has cut the roll bar mounts off so I got another disc brake axle complete that I want to rebuild as it's been sitting a while. The axle code is a 42s so 93 on with disc brakes - All good.
Where I'm struggling is hubs, stub axles and bearing kits. Confused
I have x2 FTC0942 - Originally HRC1924 and matches what came off the original axle - New Hub face is larger though.
X2 FTC3154 - Stub axles - These look very different to what came off - The ones that came off have a semi circle cut out and these seem to have different internal bits and might need different bearings. The ones that came off look more like DA3198.
x2 bearing kits DA2383 - Britpart bearing kits.
Do these work together, am i a total knob or should I calm down and carry on! Laughing
Thanks in advance
Post #770528 28th Apr 2019 3:54pm
