Home > Technical > TB for fuel tank breather
Daniel TD5
United Kingdom 1986 Defender 90 Other ST Nato Green
any one have a copy of the tb for fuel tank breather location
had my one towed away again both fuel lines and filter full of water and black crap
so putting it behind the rear light panel did not work
land rover tect said a tb has been issued
Daniel
Post #7307 15th Feb 2009 5:57pm
mse
Re: TB for fuel tank breather
Daniel
Yes but to relocate it behind the light panel flap. I cant see why this wouldnt work, i suppose unless you went deeper than it? Mike
Post #7312 15th Feb 2009 8:31pm
Tony_Hillerby
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Santorini Black
My 110 has had another ride on the back of a recovery truck. It started to make strange engine combustion noises when changing gear and accelerating away again, mostly from cold. It was also starting to get a bit shaky when starting up from cold. The dealers will be looking at it next week so we will see what happens.
Post #7317 15th Feb 2009 9:45pm
Daniel TD5
i have relocated my one behind the rear panel but that was about novemeber last year tect said they pull so much crap in the tank should have been drained last year and the fuel lines flushed through no wading ever done in my one
dealer as just rang did i fill it up with petrol Rolling with laughter
i will keep you posted
Post #7336 16th Feb 2009 9:35am
Tony_Hillerby
Just had a word with the dealers and they have replaced I think the pressure relief valve and also said that there was again water in the diesel. Last year I had the same and had the injectors , pump and fuel rail changed and the breather re located behind the flap at the rear of the wheel arch.
So tank drained and new filter fitted and system flushed out. I have not been wading or off roading as its a tow vehicle for the caravan and LR trialer.
Does this mean that the official fix does not work.
I have seen pictures of extending the breather but does this mean if I do this myself that will affect any future warranty issues on the fuel systems.
Tony
Post #7516 18th Feb 2009 11:47pm
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
Any more information on how to do the breather pipe relocation behind the light panel guys?
Cheers Rich
Post #7519 19th Feb 2009 9:29am
Daniel TD5
its back
i moved the breather pipe in november last year so it had been sucking water for over a year so the tank had loads of crap in it dealer did not carry out the TB
problem is the pump is engine mounted not in the tank as the TD5 it had two. so the tank breather is pulling more air all the time it may mean the TDCi is more Prone to water in the fuel Than the TD5 some could be coming from the pumps as well
dan
Post #7520 19th Feb 2009 10:10am
Eduardo
I have it. Mr. Green
But not idea how to post a PDF here
PM me if is still needed.
Cheers! Eduardo
Post #7525 19th Feb 2009 1:03pm
Daniel TD5
Cheers!
thanks eduardo
i have it now
it still not right very noisy from the top of the engine after it came back
Post #7559 19th Feb 2009 10:24pm
Scallops
Australia
Cheers Rich
Very simple - unclip it from it's position behind the passenger side rear wheel inside the wheel arch, lift the base of the black plastic flap that shields the passenger side rear lights, and push the tube up the LHS (looking to the back of vehicle) behind the plastic flap.
Post #7698 24th Feb 2009 6:35am
mrwoo
I'm with Russell wrote:
Cheers Rich
Thanks very much for that, I'll give it ago this weekend, just one question though. Does doing this allow fuel fumes to enter the vehicle?
Wink
Post #7700 24th Feb 2009 9:01am
Scallops
Australia
Cheers Rich
Wink
No - not at all - the area where the breather is placed is still outside the vehicle's interior.
Post #7804 27th Feb 2009 5:45am
