Home > Maintenance & Modifications > Bleeding those Bleeding Brakes |
JustFX Member Since: 10 Nov 2016 Location: Mendip Hills Posts: 190 |
Due to last year's MOT noting the imbalance of the brakes I decided to make use of the long weekend to do the callipers. So both front callipers[1] and flexy hoses changed. Used Nanocom to bleed afterwards. The fluid had been allowed to drip out, wasn't too worried as I wanted to put some fresh in.
Now the annoying part. '00 Defender Td5 110 with ABS The brakes will pump and stop but give them 5-10 seconds and I can press peddle to the floor. I have used a Nanocom to bleed the modulator (pump brake then operate command), used the individual brake tests to bleed them. Also used old skool pump peddle and then open nipple etc. Not 100% on the order it should be done in but we have tried closest to furthest from master and vice-versa. Tried Front Right, Rear Left, Front Left, Rear Right and vice-versa. Tonight it has an mk1 block of wood wedging it down after pumping up to see if moves some air about. Worried the Modulator has issues but it fires up, and when I took it on a "rather interesting drive"[2] I did get enough speed and pump to get it to skid a wheel on gravel and the ABS worked fine. [1] Got to love Paddocks, OEM means one Br*tp*rt bright zinc (silver) calliper and one AllM*kes yellow zinc (gold) caliper [2] Just a very short around the block via the lanes but as I needed to pump brakes before it would stop it was slow and needed lots of pumping. I thought it might improve if I had the engine running and I was able to give it a run. |
21st Apr 2019 7:14pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5665 |
The callipers have the bleed nipple on the top when fitted?
21st Apr 2019 8:32pm |
That would be the expected location to find the bleed nipples on brakes. I guess it is my fault that I didn't point out that when following the front right, rear left bits that I was actually bleeding the fluid from the calliper. The modulator doesn't have a bleed valve, it is just a button you can press in the Nanocom it does a burr noise etc. |
21st Apr 2019 8:38pm |
Well, we pumped and pushed the piston back and forth a few times today but still no improvement. I have resorted to asking a local mechanic to fix it as they have the ramp and space to do the vac bleed plus it needs an MOT so they can do that at the same time.
This afternoon I took the time to give it a wash. |
22nd Apr 2019 4:27pm |
