Home > Puma (Tdci) > Software Updates |
defender75 Member Since: 06 Nov 2010 Location: Germany Posts: 219 |
Is there anyway to get dealer software updates without going to the dealer?
20th Jun 2011 10:42pm |
Not unless you got the tools to do it!! How would you get the update into the vehicle and check everything was running ok? If you go through life with your head in the sand....all people will see is an ar5e!!
21st Jun 2011 10:37am |
BM? |
21st Jun 2011 4:58pm |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 |
From germany and not sure what a BM is
21st Jun 2011 5:00pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
BM = ?? Basic Maintenance. LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
21st Jun 2011 5:10pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
It is easy to do, just buy this: http://www.budgetdiagnostics.co.uk/ford/ge...2mtsbi9pg7 It comes with access to the latest upgrade files |
DefenderOfTheEarth Member Since: 09 Nov 2010 Location: Cornwall, UK Posts: 1304 |
Bavarian Motor (Works) innit.
Or Bayerische Motoren (Werke) if you're actually German. Defender 110XS SW gone... now VW California 180 4 Motion. |
21st Jun 2011 5:35pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
Maybe try talking to someone like Gary at Alive. Maybe he can sort you out by using the ATRIC?.... You could also get a modified map too at a fraction of the cost of the type Bri has linked.
Glyn |
21st Jun 2011 5:42pm |
Thanks for the info. Sorry not German just there for work most of the time. I appreciate the info. Will talk to Gary as I wanted to do a remote remap as well.
21st Jun 2011 6:50pm |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
Hi
Ill add a little info to help. To have a software update correctly installed on the car a remapping tool will just not work as the update was intended from landrover, The Dealer VBF files used to make a correct ecu software update are in 3 parts not 1 as used in all remapping tools. The remapping tool only programs PART of the ecu where the mapping structures are stored and a small part of the base ecu software, The main software of the ecu is not changed when a remapping tool is used hence why they dont add programming records You will need something like a Blackbox Soloutions Faultmate MSV2 "with built in remote remap capeability" if you require it, or Autologic possibily or as already said above an IDS/SDD dealer level tool. After the calibration update is done it then needs a pilot correction update, this will need to be compleated to finalise programming correctly which makes the running and efficency of the particular cars injectors and fuel pump match the new calibration update programed into the ecu. Typical something that a lot of dealers mis or fail to complete correctly after a program as most are so pressed for time. Pete |
22nd Jun 2011 9:18pm |
Thanks for the info. I guess I will get the dealer to do the update but of course now I am worried they won't do it correctly.
yikes |
23rd Jun 2011 3:47am |
yikes |
23rd Jun 2011 3:51am |
I had numerous issues with a software update and subsequent incompatability issues with my Autologic remap...Even when done correctly it can highlight other issues... http://www.defender2.net/forum/topic3243.h...patability Software updates can be a bain, and eat up avaliable slots in your ECU! I no longer have software updates. People in my opinion rush to have them because they are free....and they think their vehicle will perform like a Formula 1 car afterwards, I did!!! I work on the principle if your vehicle is running sweet and you are happy with it and there are no major mechanical or safety issues....If it ain't broke it doesn't need fixing!!!! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
23rd Jun 2011 1:15pm |
